Newbie Help Request
Discussion in '3CX Phone System - General' started by emischell, May 11, 2010.
  1. emischell
    May 11, 2010
    7
    I have installed the 3cx system on a Windows 2003 server and configured a few PCs with softphones. Internal calls to extension are working fine. Audio on in/out calls is one way only (audio is not getting in to the softphone from an outside phone). I am using nexVortex and the trunk indicates that it is registered and their tech support seems to think everything is OK on their end.
    I have setup a service for 3cx on my firewall (Watchguard x500) and created a NAT from the public address to the server running 3cx for 5060 (both) 5090 (tcp) and 9000-9100 (UDP).
    The firewall tests passes step 1, on 2a&b passes with warnings, and the same for Phases 3 and 4. Exit code is 53. I have several other services setup on the firewall so I'm comfortable saying that I have followed the directions in the manual.
    Anywhere in the Management console I should be looking?
    Thanks,
    Eric
  2. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    Did you set up inbound and outbound rules for these services?
  3. emischell
    May 11, 2010
    7
    Yeah,the inbound rings all extensions (it does) and the outbound strips out a 9 (it does). The calls are going through it is just an audio issue at this point.
  4. pjr
    pjr New Member
    Oct 5, 2009
    154
    have you specified the public IP you will be presenting in the contact header in the VoIP Provider > Advanced section, and also under Network Settings > Stun Server > Public IP to specify in contact and SDP?
    Paul
  5. emischell
    May 11, 2010
    7
    Thanks, Paul. I had not done either. I'll test with that.
    My ISP is also going to be replacing some equipment this week because they are seeing packet loss. I'll reply before then if your help fixes it.
  6. emischell
    May 11, 2010
    7
    Outbound calls - have voice both ways now.
    Inbound calls - no inbound audio on 3cx softphone, cell phone can hear what the person calling from the softphone is saying.
  7. emischell
    May 11, 2010
    7
    Re-reading the inbound description it is not clear.
    The person receiving the call on the softphone cannot hear any audio. The person who initiated the call can hear what the person on the softphone is saying.
  8. pjr
    pjr New Member
    Oct 5, 2009
    154
    can you perform a wireshark capture from the machine with the softphone on and post the results here?
  9. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,575
    305
    I can not get my firewall test to get past 2a.
    it tells me "UDP SIP Port is set to 5060. NO RESPONSE received. Phase 2a check FAILED."
    In firewall checked, STUN is using stun.3cx.com even though STUN is turned off in the network settings. I have also tried my external ip here.
    In my watchguard x500, I have a 1-to-1 nat range as I need my email server to do 1-to-1 as well.
    Also, I have 5060 (both), 5061(both) 5090 (both), 9000-9049 (tcp) and 10000-20000 (udp) from "Any External" to "NAT for External IP to Internal IP"
    I have read changing 1-to-1 NAT to a single helps - but I can not do that. I need the Mail server in there and the license allows for 1 1-to-1 NAT.
    Finally, Firewall Service is turned off on Win7 Device running 3cx.
    I can connect to the server from outside world but no audio.
  10. albertc
    Nov 21, 2011
    89
    Is there a reason why you use TCP instead of UDP for port 9000-9049? I believe 3CX only use UDP for RTP. And that may explain why you have one way audio. When your are streaming outbound audio with UDP 9xxx without any issue, all the incoming UDP 9xxx are not being deliver to your server since 9000-9049 UDP are not mapped.
  11. craigreilly
    Feb 1, 2012
    3,575
    305
    No reason I was using tcp. I am sure I looked at that 100 times and kept saying "yep that's all right"
    Do I have too many ports open?
  12. albertc
    Nov 21, 2011
    89
    For port 9000-9049, you MUST use UDP. TCP won't work.
  13. craigreilly
    Feb 1, 2012
    3,575
    305
    Yep got that now. Audio is working.
    We are only doing remote xtnsions not vo-ip.
    Can I close any of those ports?
    And - thank you!!!!
  14. albertc
    Nov 21, 2011
    89
    No problem. You can close the 10000-20000 udp. 3CX doesnt listen to them. Also, if you do not use SIP Proxy Manager at a remote location, you can turn off TCP 5090.
  15. craigreilly
    Feb 1, 2012
    3,575
    305
    Perfect.
    I do need the 1-to-1 nat correct?
  16. albertc
    Nov 21, 2011
    89
    Not with 3CX. And I dont think you'll need to use 1 to 1 NAT for your email server also. In most situation, Port forwarding will do the job just fine. All you need is to forward all the necessary ports your email server required (i.e. TCP/25 for smtp, TCP/143 for IMAP, TCP/80 , 443 for Web mail access, ...etc.).
  17. craigreilly
    Feb 1, 2012
    3,575
    305
    Good to know. I know our ms exchange server needs it otherwise our email flow stops completely.
    When we changed ISP I forgot to change the 1 to 1. As soon as I did mail started flowing again...
