Newbie Problems
Discussion in '3CX Phone System - General' started by hgomez29, Apr 17, 2007.
  1. hgomez29
    Apr 17, 2007
    5
    I cannot get it to "hear" the # key on softphone and i'm unable to log into voicemail and do anything with that, everything else seems to be working fine, question though, is there a particular button to "reset" the server or do I need to go into services and shut all the 3CX* programs off and then restart them? thanks!
  2. NigelG
    Mar 29, 2007
    48
    Which softphone are you using? have you tried x-lite or sjphone, also dialling plan could be causing you issues.
    At the moment you need to restart the 3CX services manually from the services control panel on your server.
    Hope this helps
    Regards
    NigelG
  3. hgomez29
    Apr 17, 2007
    5
    thanks for the response, yes i'm using SJphone and i'm not sure what you are referring to as far as calling plan, right now i'm having issues just with local, i can dial each ext but like for vm I can't get it to respond to the key tones
  4. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,915
    221
    Is your soft phone generating the DTMF out of band or in band? It should be in band, the exact same way that it works from a normal phone. To check this you can dial another extension, press the buttons and see if you hear the DTMF tones being generated.
  5. hgomez29
    Apr 17, 2007
    5
    Yes i can hear the DTMF tones but its still not responding, now I can call extensions like i said before and after the pre-determined time it will go to vm but when the voicemail extension is dialed it answers and i enter the extension number and after about 15 seconds, its says thank you, goodbye and hangs up
  6. Anonymous
    Anonymous Guest
    Yep, DTMF allright.
    Bind the phone to the media server under the advanced settings for the extension.
  7. hgomez29
    Apr 17, 2007
    5
    I did the binding for the extensions, here a copy of the sever log:
    17:10:01.375 StratInOut::eek:nCancel Call from Ext.1002 to 9999 has been terminated
    17:10:00.375 ??: from 'Win-2003-Svr-1:0/MediaServer':EP 0000001D@. Recording cancelled. Failed to open file "C:DOCUME~1NETWOR~1LOCALS~1TempRWVA.tmp" for writing
    17:09:55.734 CallLegImpl::eek:nConnected Established media channel for Ext.1002: remote=192.168.0.12:49216; local=208.180.188.112:62600
    17:09:55.687 CallConf::eek:nIncoming Incoming call from Ext.1002 to sip:1003@208.180.188.112
    17:08:33.515 ??: SL: connected Win-2003-Svr-1:0/PHPExtension_0 at [Win-2003-Svr-1:0]/PHPExtension_0
    17:08:21.453 ServRegs::eek:nAdd Registered: Ext.1002
    17:08:01.015 ClientRegs::eek:nSuccess Registration of sip:hgomez29@fwd.pulver.com is successful
    17:07:57.906 ExtLine::Register_ Send registration for "840695"<sip:hgomez29@fwd.pulver.com>
    17:07:57.906 ExtLine::Register_ Use External IP for device line registration DN='10000' device='FWD'
    17:07:57.859 StunClient::process STUN resolved external IP=208.180.188.112:62557 by server 69.90.168.13
    17:07:56.734 StunClient::process Send initial STUN request to 69.90.168.13
    17:07:56.703 IVRConnected: IVR Server is connected
    17:07:56.703 ??: SL: connected Win-2003-Svr-1:5483/IVRServer at [Win-2003-Svr-1:5483]/IVRServer
    17:07:56.703 ??: SL: connected Win-2003-Svr-1:0/VoiceBoxManagerService at [Win-2003-Svr-1:0]/VoiceBoxManagerService
    17:07:56.703 MediaServerConnected: Media Server is connected
    17:07:56.703 ??: SL: connected Win-2003-Svr-1:0/MediaServer at [Win-2003-Svr-1:0]/MediaServer
    17:07:56.625 CallMgr::Stack::thread ** Enter Stack Loop **
    17:07:56.625 DBA: ** Database connection Ok **
    17:07:56.546 CallMgr::DumThread::thread ** Enter DUM Thread **
    17:07:56.531 CallMgr::Stack::Initialize ** Adding transports **
    17:07:56.531 CallMgr::Initialize ** Initializing SIP stack **
    17:07:56.343 CallMgr::Initialize Version: 3.0.1699.0
    17:07:56.343 CallMgr::Initialize Start 3CX PhoneSystem Call Manager
    and its still now working ..... :cry:
  8. Anonymous
    Anonymous Guest
    Looks like you have more than one problem.
    Access right to the local directory and you have two different subnets.
    Try to eliminate the access rights to you local directory first, 3cx creates a user see if the user has enough rights to that directory.
  9. hgomez29
    Apr 17, 2007
    5
    yes the phone system has FULL rights to the parent and temp directories i hvae it actually connecting now but when i go to record the following is dumped in the log:
    22:06:07.671 StratInOut::eek:nCancel Call from Ext.101 to 999 has been terminated
    22:06:06.671 ??: from 'Win-2003-Svr-1:0/MediaServer':EP 00000010@. Recording cancelled. Failed to open file "C:DOCUME~1PHONES~1LOCALS~1TempRWV7F.tmp" for writing
    22:05:52.406
    ??: from 'Win-2003-Svr-1:0/MediaServer':DTMF detection off on EP:00000010@
    22:05:48.656 CallLegImpl::eek:nConnected Established media channel for Ext.101: remote=192.168.0.12:49158; local=192.168.0.130:7030
    22:05:48.609 CallConf::eek:nIncoming Incoming call from Ext.101 to
    sip:999@208.180.188.112
  10. Anonymous
    Anonymous Guest
    Good noticed you got all on the same network segment.
    All you need to do now is:
    1. Open the 'Environment Variables' window (Start/Control Panel/System/Advanced/Environment Variables).
    2. Please set the 'TEMP' and 'TMP' system variables (not user variables for the current user !!!) to the 'C:\WINDOWS\TEMP' value (or shorter one, like 'C:\TEMP').
    3. Restart 3CX IVR Service and 3CX Media Server Service.
    (Not my solution, Alexander from the 3cx support team posted this one earlier).
