Newbie Question - Analog Phones
Discussion in '3CX Phone System - General' started by zoomzoomvince, Jul 31, 2008.
  1. zoomzoomvince
    Jul 31, 2008
    19
    I am new to 3CX and I have what I hope is a simple question. I have 3 analogue phones (1 fax machine and 2 Polycom conference phones). How should I connect these. From what I have seen so far I need ana ATA - question is what one should I get. I have seen the Patton SmartNode 4114 but they are quite expensive. Are there any other products which do the job and work with 3CX ???
    Thanks.
  2. Anonymous
    Anonymous Guest
    You can try the LinkSYS SPA-3102.
    It's what we test with here in the lab.
    Thanks,
  3. zoomzoomvince
    Jul 31, 2008
    19
    But doesn't that have only 1 FXS and 1 FXO port. I would need 3 ports. I see that the SAP2002 has 2 RJ11 ports.
    Grandstream have the GXW4004 with 4 FXS ports, might be a better bet ??
  4. Anonymous
    Anonymous Guest
    The grandstream *should* be fine, but this has not been specifically tested.
    Our approach here is to have a simple ATA such as the 3102 per device.
    Thanks,
  5. Henk
    Henk Member
    Nov 13, 2007
    250
    For the phones and fax you need FXO, the stuff that you plug into your wall plug.
    FXS is for the lines coming in, the stuff you coming out of your wall plug
    SPA3102 has one FXO and one FXS
    H.
  6. zoomzoomvince
    Jul 31, 2008
    19
    Thanks for the info, much appreciated. SPA3102 it is then.
