Newbie Question
Discussion in '3CX Phone System - General' started by ndraves, Feb 7, 2009.
  1. ndraves
    Jul 22, 2007
    29
    Hi. I'm installing 3CX for the first time and I'm having problems getting it connected to my BroadVoice. The server logs are below.
    Any ideas?
    Thanks.
    Nabil
    16:10:44.468 [CM503015]: Call(1): Attempt to reach <sip:6891972@10.10.0.5:5060> failed. Reason: Not Registered
    16:10:44.468 [CM503016]: Call(1): Target is not registered: VoIPline:891972 dialed on (AnyLine@BroadVoice)
  2. ole
    ole
    Feb 5, 2009
    10
    The first line look as if you try to place an outside call. But you cannot do that, because you are not registered witih your provider. Did you check your pot/trunk-status? are the buttons green or red?
  3. ndraves
    Jul 22, 2007
    29
    You are correct, it isn't registered. Where do I find how to register it?
    Thanks!
  4. ole
    ole
    Feb 5, 2009
    10
    In the management console, there is a chapter 'VoIP Provider'. There you have to add your provider. You need the information about SIP-server, account and password. If your provider is not on the list, use 'generic'. That should work. If not, set your log to 'verbose' and post again.
