Newby Question - Codecs
Discussion in '3CX Phone System - General' started by adza, Feb 12, 2008.
  1. adza
    Feb 12, 2008
    22
    Sorry for this question, I'm sure it's simple, but I couldn't find info in the manual or through the Live Configuration.
    How can one set the CODEC to use for VOIP providers?
    (ie, I have registered an 'outside line' via one of my VOIP providers, and would like to be able to choose the codec that is used.
    Thanks & Regards
    Adam
  2. eddietang
    Oct 3, 2007
    31
    Click on 'Lines -> Manage'
    Click on the link 'Gateway / Provider' name of your VoIP provider
    Click on 'Codec priorities'
    Move the 'Available codecs' (left column) to the 'Assigned codecs' (right column) in your preferred sequence. :p
  3. adza
    Feb 12, 2008
    22
    Hi eddietang,
    I was looking in the wrong area! Thanks for your reply. You've made my evening. :)
    Thanks & Regards
    Adam.
