Nexus One - WiFi...
Discussion in 'Android' started by liberty2, Feb 6, 2011.
  1. liberty2
    Sep 16, 2010
    10
    Hello all. I am having trouble registering the Nexus One. I am able to register and use the phone internally (when on the same LAN as the server). However, when I try to register and use the 3CX phone on another WiFi network (externally), it does not work. Specifically, it indicates that it is registered, but when I try to place a call, it dials and never connects.
    I am able to use the 3CX client for windows both internally and externally.
    Here is some of the log from when I try to place a call from the Android...
    Code:
    22:22:16.522  Requests rate from IP {public IP of Android} is too high! Blacklisted for 167 seconds
    22:22:16.522  [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
      INVITE sip:101@{domain name} SIP/2.0
      Via: SIP/2.0/UDP {public IP}:5060;rport=5060;branch=z9hG4bKPj5sLnn3aeL30e3yhSM7CeLJsqaoyTyc1I
      Max-Forwards: 70
      Contact: <sip:105@{public IP}:5060>
      To: <sip:101@{domain name}>
      From: <sip:105@{domain name}>;tag=L7ixN7MvAZXmJJgXkGiAvw7kTYJN0jAN
      Call-ID: 1-ejbUIDiHx3l7VB-ynxA7MhB13VCwVu
      CSeq: 29872 INVITE
      Session-Expires: 1800
      Min-SE: 90
      Allow: PRACK, INVITE, ACK, BYE, CANCEL, UPDATE, SUBSCRIBE, NOTIFY, REFER, MESSAGE, OPTIONS
      Supported: replaces, 100rel, timer, norefersub
      User-Agent: 3CXPhone for Android 1.2.9
      Content-Length: 0
    If you would like to try, please PM me, and I will temporarily configure an extension and send you settings. :)
    Thanks for your help.
    RR
  2. liberty2
    Sep 16, 2010
    10
    Also, I am able to register the 3CX Phone for Windows from both the internal and external IP addresses.
