NexVortex config
Discussion in '3CX Phone System - General' started by Bob Denny, Mar 26, 2009.
  1. Bob Denny
    Bob Denny New Member
    Feb 21, 2009
    131
    With 7.1 RC2 I noted a couple of things for NexVortex
    1. Reinvite and Replaces are not set, yet NexVortex appears to support them
    2. PBX Audio is set, and it appears not to be required
    3. Outbound caller ID can be controlled by 3CX, however it requires an Outbound Parameter: SIP field = Remote Party ID - Calling party : User part, Variable = "CallerNum" caller's number (default: From->User)
