nexvortex-Supported provider error to 3cx IVR/VM
Discussion in '3CX Phone System - General' started by giovanni0826, Jul 1, 2007.
  1. giovanni0826
    Apr 6, 2007
    53
    it seems that nexvortex doesn't recognize or support our IVR/VM. i thought this provider was tested and support?
    19:12:43.000 MediaServerReporting::FilePlayer [MS007005] Call(11) Ln:10000@VORTEX: Failed to open file "C:\Program Files\3CX PhoneSystem\Bin\..\Data\Ivr\Temp\ivr\prmpt5746f9.wav" to play on EP 00000012@. 'silent' RTP stream will be sent.
    19:12:41.796 StratInOut::eek:nHangUp [CM104007] Call(11): Call from Ln:10000@VORTEX to 9990 has been terminated by Ln:10000@VORTEX; cause: unknown
    19:12:41.796 CT_IVR::Invite [CM005004] Re-INVITE to IVR/VMail is not supported!
    19:12:41.406 CallLegImpl::eek:nConnected [CM103001] Call(11): Created audio channel for Ln:10000@VORTEX (207.218.174.182:50808) with Media Server (my.ip.address:9008)
    19:12:26.125 CallConf::eek:nProvisional [CM103003] Call(11): Ext.1100 is ringing
    19:12:26.046 CallConf::eek:nIncoming [CM103002] Call(11): Incoming call from 561338xxxx (Ln:10000@VORTEX) to sip:1954678xxxx@66.23.129.253:5060
    this show incoming call to extension 1100. ext. 1100 is set to roll over to VM when not answered.
  2. Costas3CX
    Costas3CX New Member
    Jan 23, 2007
    217
    Hey there giovanni0826
    Yes we had tested in the past with NexVortex and all was good. I tried again this morning to configure it and see if it works but it seems that I might have misplaced their login details. I will test this as soon as their support sends me the new login details to test with and will come back to you with an answer...
    Regards
  3. giovanni0826
    Apr 6, 2007
    53
    thanks. please be sure to test with server 66.23.136.140. this is the one that new customers are assigned, you know apples for apples. also i would be more then happy to send you my account info. i have your email address, i'll send it.
  4. Costas3CX
    Jan 23, 2007
    217
    Hello sir
    I have tested this. It seems that NexVortex does invites/reinvites in a strange way that system doesn't handle. I checked with other providers and forwarding to IVR is not a problem. I have notified our engineers about this, and they will look into this and see it there is a way to fix this for future versions.
  5. Costas3CX
    Jan 23, 2007
    217
    I know am I quoting myself, its just to emphasize the problem is not really with Nexvortex although there is a reinvite send during the call establishment procedure which we don't usually get. The problem was that we were blocking re-invites during forwarding to DR because there was no reason to put someone on hold for example while listening to DR. So now it is fixed and we will post it soon on the website..
    So to whoever has this problem, please be a little patient and we will place this on the website soon.
  6. mvwarehouse
    Jul 14, 2007
    Any update?
    I have the same issue with BroadVoice.
    "Re-INVITE to IVR/VMail is not supported!"
    My version was 3.0.2328.0
    I rolled back to 3.0.1928.0
    Mark
  7. support@nexvortex
    Aug 30, 2007
    6
    This is nexvortex support. We do a REINVITE on outbound calling as part of the authentication challenge process. The only other REINVITE's we do are for call transfer, Music on Hold, Hold but that is initiated by the customer premise equipment and on T.38 negotiation after the call is setup. We keep call traces on ALL calls and very happy to get to the bottom of the problem. Just email us at support@nexvortex.com to setup a time to test.
  8. nb
    nb Support Team
    Jun 7, 2007
    2,147
    173
    Hi <support@nexvortex>
    Seems that everything is working fine at the moment. We even added a template in our PBX to facilitate the configuration process for the end user.
    Thanks for the offer.
  9. support@nexvortex
    Aug 30, 2007
    6
    nexVortex template
    Hi nickybrg,
    Can you please verify one piece of the template, please? From some conversations I have had with customers, it seems that the proxy IP address in the template is incorrect.
    Our proxy IP address is 66.23.129.253. Can you please see that this is used as the default setting in the template?
    Thanks!
    support@nexVortex
