nexvortex-Supported provider error
Discussion in '3CX Phone System - General' started by giovanni0826, Jun 30, 2007.
  1. giovanni0826
    Apr 6, 2007
    53
    i configured the provider nexvortex as per the template (had to change the IP) and i get the following error on inbound calls.
    11:26:38.843 ClientRegs::eek:nSuccess [CM113005] Registration of sip:globalnet@66.23.129.253 is successful
    11:26:38.578 ExtLine::Register [CM110004] Send registration for <sip:globalnet@66.23.129.253>
    11:26:38.578 ExtLine::Register [CM110001] Use External IP for device line registration DN='10002' device='testing2'
    11:17:33.296 StratInOut::eek:nHangUp [CM104007] Call(63): Call from Ln:10002@testing2 to 8000 has been terminated by Ln:10002@testing2; cause: unknown
    11:17:33.296 CT_IVR::Invite [CM005004] Re-INVITE to IVR/VMail is not supported!
    11:17:33.109 CallLegImpl::eek:nConnected [CM103001] Call(63): Created audio channel for Ln:10002@testing2 (207.218.174.182:52780) with Media Server (my.ip.address:9002)
    11:17:33.093 CallConf::eek:nIncoming [CM103002] Call(63): Incoming call from 954585xxxx (Ln:10002@testing2) to sip:1954678xxxx@66.23.129.253:5060
    any ideas
  2. giovanni0826
    Apr 6, 2007
    53
    I FIGURED IT OUT, YEAHHHH.
    incoming calls will be rejected if routed to Digital Receptionist. WHY
