nexVortex
Discussion in '3CX Phone System - General' started by giovanni0826, Dec 4, 2007.
  1. giovanni0826
    Apr 6, 2007
    53
    Has any one been able to register with nexVortex or InPhonex with the V5 RC 2?
  2. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    Did you ever get your line registered with nV?
    A couple of us have and can call out no problem. No incoming calls though but they are working on it.
  3. giovanni0826
    Apr 6, 2007
    53
    OH YEah! i apologize yes i have and i also got it to connect but only for a brief second and then drops. it can only connect through to an extension, theres an issue with the IVR and reinvites. one of the engineers on it.
  4. dyntech
    dyntech New Member
    Mar 28, 2007
    160
    I have no registration problems with nexVortex but I do notice a slightly longer lag before the connection.
  5. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    Yes, we've found and fixed a bug which caused immediate drop of incoming calls from nexVortex.
  6. ecwilson
    ecwilson New Member
    Jul 12, 2007
    118
    Can anyone post their basic setting for Inphonex & Nexvortex.
    We are still having problems getting them to register in 3CX V5RC2?
    ecwilson
  7. dyntech
    dyntech New Member
    Mar 28, 2007
    160
    So if you fixed the bug, how do we get the fix?
  8. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,994
    304
    We are uploading it now. Please give us about 15 mins.
    We have prepared a new build. It addresses numerous issues with rc 2. It fixes INphonex, Nexvortex, issues with installing in DMZ or on public IP etc.
  9. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    I can confirm that this now works with nexvortex.
  10. ecwilson
    ecwilson New Member
    Jul 12, 2007
    118
    InPhonex now works too.
    ecwilson
