NFP licence
Discussion in '3CX Phone System - General' started by malcm, Feb 23, 2008.
  1. malcm
    May 27, 2007
    8
    Hi, my NFP licence key no longer works with v5 is this an upgrade problem.
    Have tried emailing the person who issued it but the address no longer exists.
  2. aguilar
    aguilar New Member
    Jul 19, 2007
    169
    hi
    did you try to place the key again? i meano running the latest version
    cheers
  3. aguilar
    aguilar New Member
    Jul 19, 2007
    169
    does it work Malcm?
  4. malcm
    May 27, 2007
    8
    No hasn't worked since the upgrade, have copied and pasted from the original email but still no good
  5. Urbok
    Urbok New Member
    Jul 14, 2007
    120
    I've the same problem. I've activated my "expert" key 2 month ago on an old v5 release. Now I've done a fresh reinstall (restoring configuration from a backup) but I've loosed the licence activation.
    If I try to resubmit my key I obtain an error.
    please, how can I re-activate my licence?
  6. h2009
    h2009 Member
    Mar 15, 2008
    447
    Contact the place where you got your license, and they will issue you with a new one
