nginx service don't start after upgrade from v14 [solved]
Discussion in '3CX Phone System - General' started by ccalza, Jul 11, 2016.
  1. ccalza
    Jun 23, 2011
    11
    In Windows event log I found this
    Child process [5228 - C:\Program Files\3CX Phone System\Bin\nginx\nginx.exe "-pC:\Program Files\3CX Phone System\Bin\nginx" ] finished with 1
    rollback to v14
  2. roadwings
    May 16, 2015
    49
    14
    Re: nginx service don't start after upgrade from v14
    Trust me, verify that windows update it working and that you have ALL windows updates installed.
  3. ccalza
    Jun 23, 2011
    11
    I start Windows update on 2012 R2 (75 updates to install) and try v15 setup again tomorrow. I report back
  4. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    Yes please update your system first. Then reinstall again if problem still persist send me a pm so we can have a look.
  5. robxbl69
    Jun 8, 2013
    24
    I had loads of issues with NGINX not starting due to SSL key not matching the certicate or the format of the certificate. Suggest you look at the NGINX error.log to see why it didn't start. Hope this helps...
  6. ccalza
    Jun 23, 2011
    11
    After applying all the Windows updates, I've removed v14 and install back v15 with success. Now nginx service working fine and I can access 3CX Web console.
    Thanks for support
  7. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    Thanks for updating us in regarding this, yes it is important that sometimes we maintain our systems with updates.
