No answer timeout
Discussion in '3CX Phone System - General' started by novacom, Sep 19, 2011.
  1. novacom
    Feb 23, 2011
    No matter what number higher than 60 secs I set the No answer time out in the forwalding rules of an extension, it seems always to be 60 secs. This is tested with cisco 504g and several grandstream models if that has anything to do with it. The 3cx soft phone doesn't have this "bug" and it works with time out of 180 ringing fo the full 3 minutes.
    Any ideas?
  2. nb
    nb Support Team
    Jun 7, 2007
    2,111
    143
    Wireshark will answer your problems.
    It seems that is the cisco spends 60 seconds in ringing, it sends a temp unavailable.
    Grandstream also does the same.
    Snom does not and leaves it up to the server.
    Yealink, aastra, 3CX Phone, neither.
    Seems like the affected phones are polycom cisco and grandstream. We will check with the manufacturers but if you find something before let me know.
  3. nb
    nb Support Team
    Jun 7, 2007
    2,111
    143
    for grandstream
    go in account settings,
    Ring Timeout:
    Default 60 seconds
    (in seconds. Between 30-3600, default is 60)
    do this 3600 for example and then let the server decide based on the busy timeout
