No audio ext-ext dialing....
Discussion in '3CX Phone System - General' started by pacpac, Feb 20, 2012.
  1. pacpac
    Jan 12, 2012
    45
    Hi, I get no audio either way when dialing extension to extension. Outbound through VoIP provider and Inbound via Direct SIP works just fine. I have 3CX on a dedicated server with Static IP and turned off STUN, and a PAP2T connected to 3CX (STUN disabled). Any ideas how I can get audio on extension-extension?
  2. pacpac
    Jan 12, 2012
    45
    For the moment it is solved, had to untick 'Supports Re-Invite' and 'Support 'Replaces' Header' on each extension, I do now have audio when dialing extension to extension. Ref, my earlier post http://www.3cx.com/forums/support-replaces-header-and-supports-re-invite-25297.html
  3. misstake2012
    May 23, 2011
    40
    do you use one local subnet or more?!
  4. misstake2012
    May 23, 2011
    40
  5. pacpac
    Jan 12, 2012
    45
    Thanks, use only one local subnet on the server, 255.255.255.255, and one subnet on the LAN where the PAP2T is connected, 255.255.255.0.
