no audio for outgoing calls via proxy
Discussion in '3CX Phone System - General' started by rcinfo, Feb 18, 2013.
  1. rcinfo
    Nov 18, 2008
    6
    Hi all,
    I have a remote office with three Grandstream gxp285 phones connected to the 3cx pbx via proxy manager, on incoming calls I can hear and talk with no problems, on outgoing calls no voice in no way. The extensions are set to 'deliver audio on'.
    in th 3cx activity log I can read:
    [MS105000] C:142.2: No RTP packets were received:remoteAddr=127.0.0.1:10188,extAddr=0.0.0.0,localAddr=127.0.0.1:7460
    can you please help?
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,083
    61
    The local 3CX system is indicating the voice packets are not being received.
    Have you made all the proper adjustments to your firewall and have you run the firewall checker?
  3. rcinfo
    Nov 18, 2008
    6
    thank you for your reply but I know what 3cx is telling me, what I don't know is why.
    I know that tunneling should solve all issues about port forwarding and firewalling, isn't it?.
    Anyway I opened and forwarded ports from 5060 to 5490, 9000 to 9049, even if I suppose the only necessary port to be opend is 5090 (3cx tunnel) and the rtp stream should flow thru it once the tunnel connection is established.
    I have static IP address on both sides of the tunnel, one vigor router on the remote side and one zywall5 on the server side.
    Also have a couple of 3cx softphone connecting from elsewhere that works correctly using 3cx tunnel.
    So I think that the problem may be on the client-remote-proxy side, what do you think about?
  4. lneblett
    Sep 7, 2010
    2,083
    61
    Tunneling will solve many issues but mostly for those locations that try and block SIP in the first place; hence why there still needs to be the tunneling ports open on the receive end.
    The best bet is to get a wireshark capture. Using it, possibly at both ends, we can see where the RTP packets are being directed. You don't have more than one NIC installed anywhere on the same machine, do you?
  5. rcinfo
    Nov 18, 2008
    6
    Well, I was running the 3cx pbx on a virtual machine, so did you call me a question. Even if, as I just said, the 3cxPhone worked without any problem.
    Just yesterday I installed the PBX on a physical machine but nothing changed, on outgoing calls I cannot hear voice and the activity log shows as follow:
    this call is not working (outgoing from proxy->grandstream phone to 3cxphone)
    09:01:40.125 [MS105000] C:17.1: No RTP packets were received:remoteAddr=127.0.0.1:10038,extAddr=0.0.0.0:0,localAddr=127.0.0.1:7058
    09:01:38.093 [CM503008]: Call(17): Call is terminated
    09:01:27.078 Session 16812 of leg C:17.1 is confirmed
    09:01:26.468 [CM503007]: Call(17): Device joined: sip:302@127.0.0.1:1251;rinstance=60b7cdaa068468e8
    09:01:26.468 [CM503007]: Call(17): Device joined: sip:132@192.168.20.31:5060;transport=udp;user=phone
    09:01:26.468 [MS210003] C:17.1:Answer provided. Connection(transcoding mode[unsecure]):127.0.0.1:7058(7059)
    09:01:26.468 [MS210001] C:17.2:Answer received. RTP connection[unsecure]: 127.0.0.1:10040(10041)
    09:01:26.468 Remote SDP is set for legC:17.2
    09:01:23.453 [CM505001]: Ext.302: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone 5.0.14900.0] PBX contact: [sip:302@127.0.0.1:5060]
    09:01:23.453 [CM503002]: Call(17): Alerting sip:302@127.0.0.1:1251;rinstance=60b7cdaa068468e8
    09:01:22.984 [CM503025]: Call(17): Calling Ext:Ext.302@[Dev:sip:302@127.0.0.1:1251;rinstance=60b7cdaa068468e8]
    09:01:22.984 [MS210002] C:17.2:Offer provided. Connection(transcoding mode): 127.0.0.1:7060(7061)
    09:01:22.937 [CM503004]: Call(17): Route 1: Ext:Ext.302@[Dev:sip:302@127.0.0.1:1251;rinstance=60b7cdaa068468e8]
    09:01:22.937 [CM503010]: Making route(s) to <sip:302@192.168.10.10:5060;user=phone>
    09:01:22.937 [MS210000] C:17.1:Offer received. RTP connection: 127.0.0.1:10038(10039)
    09:01:22.937 Remote SDP is set for legC:17.1
    09:01:22.937 [CM505001]: Ext.132: Device info: Device Identified: [Man: Grandstream;Mod: GXP Series;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream GXP285 1.2.5.3] PBX contact: [sip:132@127.0.0.1:5060]
    09:01:22.937 [CM503001]: Call(17): Incoming call from Ext.132 to <sip:302@192.168.10.10:5060;user=phone>
    09:01:22.937 [CM500002]: Info on incoming INVITE:
    INVITE sip:302@192.168.10.10:5060;user=phone SIP/2.0
    Via: SIP/2.0/UDP 127.0.0.1:5080;branch=z9hG4bK-d8754z-ef7c948cbd7a4132-2---d8754z-;rport=5080;received=192.168.10.10
    Via: SIP/2.0/UDP xxx.xxx.xxx.xxx:51328;branch=z9hG4bK-d8754z-tunneltid-1---d8754z-;rport
    Via: SIP/2.0/UDP 192.168.20.31:5060;branch=z9hG4bKef7c948cbd7a4132
    Max-Forwards: 68
    Record-Route: <sip:3cxBridge@127.0.0.1:5080;user=proxy;uri="xxx.xxx.xxx.xxx:51328">
    Contact: <sip:132@192.168.20.31:5060;transport=udp;user=phone>
    To: <sip:302@192.168.10.10:5060;user=phone>
    From: "Carlo"<sip:132@192.168.10.10:5060;user=phone>;tag=d0bdb3d60f0e7baf
    Call-ID: b2cf7be87e88f78b@192.168.20.31
    CSeq: 17472 INVITE
    Allow: INVITE, ACK, CANCEL, BYE, NOTIFY, REFER, OPTIONS, INFO, SUBSCRIBE, UPDATE, PRACK, MESSAGE
    Proxy-Authorization: Digest username="132",realm="3CXPhoneSystem",algorithm=MD5,uri="sip:302@192.168.10.10:5060;user=phone",nonce="414d535c073513d260:fba2d39dd89b3f74c1878ae785ea3538",response="3257a905eada7f12194032e6c5164294"
    Supported: replaces, timer, path
    User-Agent: Grandstream GXP285 1.2.5.3
    Content-Length: 0
    P-Early-Media: Supported
    this call is working (incoming from 3cxphone to proxy->grandstream phone)
    09:02:32.671 [CM503008]: Call(18): Call is terminated
    09:02:26.656 Currently active calls - 1: [18]
    09:01:56.140 Session 16820 of leg C:18.1 is confirmed
    09:01:55.656 [CM503007]: Call(18): Device joined: sip:132@192.168.20.31:5060;transport=udp;user=phone
    09:01:55.656 [CM503007]: Call(18): Device joined: sip:302@127.0.0.1:1251;rinstance=60b7cdaa068468e8
    09:01:55.640 [MS210003] C:18.1:Answer provided. Connection(transcoding mode[unsecure]):127.0.0.1:7062(7063)
    09:01:55.640 [MS210001] C:18.2:Answer received. RTP connection[unsecure]: 127.0.0.1:10050(10051)
    09:01:55.640 Remote SDP is set for legC:18.2
    09:01:54.656 Currently active calls - 1: [18]
    09:01:52.625 [CM505001]: Ext.132: Device info: Device Identified: [Man: Grandstream;Mod: GXP Series;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream GXP285 1.2.5.3] PBX contact: [sip:132@127.0.0.1:5060]
    09:01:52.625 [CM503002]: Call(18): Alerting sip:132@192.168.20.31:5060;transport=udp;user=phone
    09:01:52.015 [CM503025]: Call(18): Calling Ext:Ext.132@[Dev:sip:132@192.168.20.31:5060;transport=udp;user=phone]
    09:01:52.015 [MS210002] C:18.2:Offer provided. Connection(transcoding mode): 127.0.0.1:7064(7065)
    09:01:51.968 [CM503004]: Call(18): Route 1: Ext:Ext.132@[Dev:sip:132@192.168.20.31:5060;transport=udp;user=phone]
    09:01:51.968 [CM503010]: Making route(s) to <sip:132@192.168.10.10:5060>
    09:01:51.968 [MS210000] C:18.1:Offer received. RTP connection: 127.0.0.1:10046(10047)
    09:01:51.968 Remote SDP is set for legC:18.1
    09:01:51.968 [CM505001]: Ext.302: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone 5.0.14900.0] PBX contact: [sip:302@127.0.0.1:5060]
    09:01:51.968 [CM503001]: Call(18): Incoming call from Ext.302 to <sip:132@192.168.10.10:5060>
    09:01:51.968 [CM500002]: Info on incoming INVITE:
    INVITE sip:132@192.168.10.10:5060 SIP/2.0
    Via: SIP/2.0/UDP 127.0.0.1:5080;branch=z9hG4bK-d8754z-da21697df947ec3a-2---d8754z-;rport=5080;received=192.168.10.10
    Via: SIP/2.0/UDP 94.37.179.75:6355;branch=z9hG4bK-d8754z-tunneltid-1---d8754z-;rport
    Via: SIP/2.0/UDP 127.0.0.1:1251;branch=z9hG4bK-d8754z-da21697df947ec3a-1---d8754z-;rport=1251
    Max-Forwards: 68
    Record-Route: <sip:3cxBridge@127.0.0.1:5080;user=proxy;uri="xxx.xxx.xxx.xxx:6355">
    Contact: <sip:302@127.0.0.1:1251;rinstance=60b7cdaa068468e8>
    To: <sip:132@192.168.10.10:5060>
    From: "Roberto"<sip:302@192.168.10.10:5060>;tag=b862354a
    Call-ID: MWExNGU4NThhMDhiZGJjYjNiMmZkYzRkOWVkMWQ0ODU.
    CSeq: 2 INVITE
    Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE
    Proxy-Authorization: Digest username="302",realm="3CXPhoneSystem",nonce="414d535c073513ef29:2eac7ad96035fda5c2d1d175a8eeb560",uri="sip:132@192.168.10.10:5060",response="ab9647a13ef4f85a6daf3beb5a8ee6d1",algorithm=MD5
    Supported: replaces
    User-Agent: 3CXPhone 5.0.14900.0
    Content-Length: 0
