No Audio from External Extensions
Discussion in '3CX Phone System - General' started by hanz007, Oct 26, 2007.
  1. hanz007
    Oct 26, 2007
    I successfully setup 3cx with all internal extension (entension within the LAN) working well. Got to register also externanal extension but the problem is when these extensions try to call internal extension, there is no audio but we the called party rings. Is there anything that needs to open such as ports from the router? I would appreciate any help. this is the only missing link. The setup is built on Windows XP. Internet connection is through a router (lynksis).
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Please take a look at this post http://www.3cx.com/forums/categories-1/3cx-phone-system-general-1/the-portforwarding-faq-hope-this-gets-a-sticky-1697/
  3. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    You don't need to do anything with ports and router if you can receive audio.
    It seems a NAT problem in remote network or incorrect configuration of phone.
    You need to configure external phone to use STUN (discover global address)
  4. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    What phone are you using on external extension? It can be the phone has well, i have a phone here that inside the Lan works great but outside(it needs stun) doesnt work, register everything.. but no audio goes to that phone... i can hear the other party(internal) but other party cant hear me... its a firmware problem that probably isnt going to be solved since its a... cheap phone...
    Cheers
  5. hanz007
    Oct 26, 2007
    I am using both IP Phone and X-Lite softphone for testing but both dont have audio. I will try STUN. But I have question on STUN. Does the STUN setting of both the 3CX and Xlite used as external extension or any other SIP Phone should be the same?
  6. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    They dont need to be exactly the same but... its advised to use the same stun server.....
    Cheers
  7. rnoguera
    Oct 25, 2007
    89
    I had similar problems with Voip Lines. Then I installed a SIP aware firewall from Intetex and all problems disapeared immediately.
