NO Audio - Grandstream 2000
Discussion in '3CX Phone System - General' started by NickK, Feb 27, 2010.
  1. NickK
    Feb 27, 2010
    45
    Hi to everybody. I'm trying to connect my ip phone to InPhoniex VOIP provider and it work fine on incoming calls
    but i have no audio and a dialing tone on all outgoing calls.. All recommended ports are open..
    Anybody have any idea?
    Please help.
    Thank you
    11,105
    329
    Is this using 3CX or just a SIP phone to a VoIP provider setup question?
  3. NickK
    Feb 27, 2010
    45
    Idealy i want to use SIP phone with 3cx but its not working and i'm trying to connect straight to VOIP provider on line 2 to test it
  4. leejor
    11,105
    329
    You might want to go into a Grandstream forum on using the phone with a VoIP provider, for more info on the settings needed.
