No audio in voice mail
Discussion in '3CX Phone System - General' started by draven187, Jan 20, 2011.
  1. draven187
    Jan 20, 2011
    5
    I run the latest 3cx version on a windows xp fundamentals virtual machine. Incoming and outgoing calls works fine. If an incoming call goes to voice mail their is no sound/audio. If you call voice mail from an internal phone their is still no audio. If you call voice mail you see the timer running that the call is answered. The log doesn't show any faults or errors. So voice mail isn't working at all.
    I already tried installing the k-lite codec pack and installed the right (i think) audio driver. Does anybody know what can cause this problem or now a solution?
    Thanks in advanced!
    I also tried to call voice mail from the 3cx softphone, got the same problem
  2. draven187
    Jan 20, 2011
    5
    Seems like the problem exists in the polycom SPIP 430 devices i'm using, tested with a cisco ip phone and audio in voicemail works.
  3. mfm
    mfm Active Member
    Mar 4, 2010
    641
    Is this phone external.
    If is it not have you factory reset the phone, it sounds like it has stun enabled. Kindly post a wireshark capture of the issue and I will take a closer look at it.
  4. wzaatar
    Aug 1, 2007
    90
    Try checking the codecs you have enabled. If you're on the free version, PCMU/A are activated by default, I suggest you switch to iLBC and enable iLBC on the phones.
    W.
  5. draven187
    Jan 20, 2011
    5
    It doesn't matter if I call from internal to voicemail or from my cellphone to my 3cx pbx. their is still no sound when voicemail starts.
    I migrated to Server 2003 R2 and from VMServer to XenServer but that doesn't seem to help. I try to do something with the codecs and hopefully that works
    oooo.. ps. it's indeed the freeversion
  6. draven187
    Jan 20, 2011
    5
    Polycom SPIP 430 doesn't support iLBC at all.... so that solution won't work
  7. draven187
    Jan 20, 2011
    5
    Deinstalled de K-lite codec pack and installed the full K-lite codec pack. Problem solved the audio problem by calling the number and when the call goes to voicemail I get audio. Now see if it works from a internal phone to the voicemail box
  8. wzaatar
    Aug 1, 2007
    90
    Great! Any updates?
  9. HTIT
    Feb 27, 2012
    I just tried this with the klite full package on a 2003 R2 server on a fresh 3CX install with the same base issue with no audio from VM service.... did not work for me. :/
  10. m4f1050
    Sep 7, 2010
    14
    I have the same issue. I am running Server 2008 R2, KLite Mega pack and Axon Virtual PBX and I can make calls and receive calls just fine, but when I dial my voicemail (ext 199) I get no sound. And when my voicemail picks up if I don't answer my extension I hear nothing.
  11. leejor
    11,293
    361
    I'm not certain that this will still apply, but, didn't there used to be an issue, when using voicemail, if a Server didn't have an audio card/drivers?
