No Audio, incoming calls after 128 sim calls
Discussion in '3CX Phone System - General' started by kurt5132081, Jul 1, 2017.
  1. kurt5132081
    May 11, 2017
    47
    ok so we have a call centre running on 3cx professional V15 with a 256 sim call license
    calls come in via sip trunk-->DR-->queue,everything runs smoothly until we reach 128 calls, every call that comes in thereafter connects and i can see it go to the DR but there is just silence on the other end of the line.
    any assistance with this issue would be greatly apprecited
    thanks.
    11,277
    360
    Are all required ports forwarded? Running the 3CX Firewall check would confirm this.
  3. cobaltit
    cobaltit Well-Known Member
    Mar 22, 2012
    1,766
    277
    You need 2 RTP ports per concurrent call. Sounds like you probably have 9000-9250 open. I'd go 9000-9600, or higher if you do WebRTC as well
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,783
    561
    To increase the ports you will need to allow them on the firewall but also enable them on the 3CX server side.
    You will need to stop the 3cx media server service from the PBX and navigate to C:\Program Files\3CX Phone System\Bin\3cxmediaserver.ini for windows and /var/lib/3cxpbx/Bin/3cxmediaserver.ini for linux and increase the ports from 9255 to 9600. Save the changes and start the service. Let us know if that worked for you
  5. kurt5132081
    May 11, 2017
    47
    Thanks guys,i will increase the port range and see what happens
  6. kurt5132081
    May 11, 2017
    47
    I am assuming i change the line:
    LEP = PT_INT32,9255
    Change the 9255 to 9600?
  7. YiannisH_3CX
    May 10, 2016
    7,783
    561
    That is correct. Do not forget to restart the service
  8. kurt5132081
    May 11, 2017
    47
    Thanks, i will try and give feedback on result
