No Audio - No RTP Packets
Discussion in '3CX Phone System - General' started by boden, Jan 29, 2011.
  1. boden
    Nov 27, 2007
    16
    Hi!
    I am having problems with the audio (I do not hear anything) and I think is some kind of configuration issue of the router (A 3COM OfficeConnect Gigabit Firewall).
    In the log of the 3CX I get the "no RTP Packets recieved" message (
    I am trying now with the following configuration
    Custom Services List
    V # Name Protocol Start Port End Port ICMP Type Edit
    1 STUN TCP/UDP 3478 3478
    2 VOIP TCP/UDP 9000 9100
    3 3CX TCP/UDP 5060 5090
    4 4711 TCP/UDP 4711 4711
    5 3CXVarios TCP/UDP 7000 7499
    6 3CXAltos TCP/UDP 10000 56500
    V # Service Source Destination Schedule Action Config
    1 4711 ANY ANY None Allow (Source NAT:Auto)
    2 3CXAltos 192.168.1.5 ANY None Allow (Source NAT:Auto)
    3 3CXVarios 192.168.1.5 ANY None Allow (Source NAT:Auto)
    4 STUN 192.168.1.5 ANY None Allow (Source NAT:Auto)
    5 3CX ANY ANY None Allow (Source NAT:Auto)
    6 VOIP ANY ANY None Allow (Source NAT:Auto)
    7 ANY 192.168.1.0/24 192.168.0.0/24 None Allow (Source NAT:None)
    WAN to LAN Policies
    1 3CXAltos ANY 192.168.1.5 None Allow (Redirect to:None)
    2 3CXVarios ANY 192.168.1.5 None Allow (Redirect to:None)
    3 4711 ANY 192.168.1.5 None Allow (Redirect to:None)
    4 STUN ANY 192.168.1.5 None Allow (Redirect to:None)
    5 3CX ANY 192.168.1.5 None Allow (Redirect to:None)
    6 VOIP ANY 192.168.1.5 None Allow (Redirect to:None)
    7 ANY 192.168.0.0/24 192.168.1.0/24 None Allow (Redirect to:None)
    Port Trigger Policies
    V Name Service User Trigger Response Edit
    Protocol Start Port End Port Protocol Start Port End Port
    TUNNEL 192.168.1.5 TCP 5090 5090 TCP/UDP 5090 5090
    SIP 192.168.1.5 TCP 5060 5060 TCP/UDP 5060 5060
    RTP 192.168.1.5 UDP 9000 9015 TCP/UDP 10000 49000
    Any ideas?
    10,368
    228
    What are the results of the 3CX firewall test? Are you having audio issues with "remote" extensions or with VoIP providers, or both?
  3. boden
    Nov 27, 2007
    16
    I tried with the Firewall checker and I get exit message 2.
    I have this problem with VOIP Providers. I haven't tried this with remote extensions.
    I also have a SPA3102 gateway, and with that line, I do not have any problem.
  4. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    I think a remote session would be a good idea on fixing this. PM me if you want this looking into.
  5. davidbenwell
    Apr 27, 2010
    704
    Ok, i have tested 3CX Firewall checker and that reports ok.
    However after doing some more checks, it would appear that your router is not accepting remote connections, I can confrim your port forwarding is all setup fine.
    Please reset the router to its factory defaults and resetup port forwarding, if this does not work, please contact 3COM or try another router.
  6. boden
    Nov 27, 2007
    16
    I have reset my router.
    I am configuring the different settings for the ports.
    But I am still having the same problem. (But sometimes intermitent). So audio, every now and then.
