No audio- No Voice
Discussion in '3CX Phone System - General' started by sanketgroup, Jun 29, 2012.
  1. sanketgroup
    Jun 28, 2012
    97
    I have 3cx 10 installed and using Voxbean as VoIP provider.
    As client, i am using xlite.
    When Client make call from Xlite using Voxbeam trunk, calls get connected successfully.
    but there is no audio at both side. No body can hear the voice.
    I have made firewall test in 3cx, which shows everything ok.
    I have few other VoIP provider in 3cx system, however all those except Voxbeam are working very well.
    There is no audio problem with other VoIP provider.
    I changed internet connection, as we have 3 different internet lines. On all lines, i am facing same audio problem.
    I installed 3cx system in other computers also, and all of them have same audio problem.
    Interestingly, if i connect to voxbeam directly from xlite (without 3cx) and from same network, audio gets resolved. Both can hear.
    So even after changing internet lines, servers, clients there is no solution.
    I called voxbeam, they said there is no issue with them as same is working on xlite, but it does not work with 3cx. Its 3cx issue.
    i spent 28 hrs on this issue, but still i cannot solve it.
    please help me to resolve the issue.
  2. mixig
    mixig Active Member
    Dec 13, 2011
    530
    12
    Can you post wireshark log for outgoing call via Voxbean?
  3. sanketgroup
    Jun 28, 2012
    97
    ho do i capture it?
    do i need to install wireshark on the same pc where 3cx is installed?
  4. sanketgroup
    Jun 28, 2012
    97
    I see heavy log under wireshark, its very long and contains many other captures then voip.
    any way to capture particular log which we want?
  5. mixig
    mixig Active Member
    Dec 13, 2011
    530
    12
    you can filter by traffic you want to see, choose network interface in wireshark and press start then make call, then press stop, in filter field type: sip then you will see only sip traffic, then you can save file (you can choose to save only fileterd messages)
  6. gschwab
    gschwab New Member
    Mar 21, 2012
    131
  7. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    Also you may want to get with your VoIP provider as well, it may be an issue on their end or your LAN. either way youre going to want that wireshark capture on both sides.
  8. jpillow
    Jun 20, 2011
    1,342
    Did you also run a firewall checker?
  9. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,086
    64
    You may want to check and see if in the configuration setting under Voip Porviders, Advanced tab, if the "PBX Delivers Audio" box is checked. If not, you may want to try this setting.
  10. sanketgroup
    Jun 28, 2012
    97
    "PBX Delivers Audio" is checked.
    But what i did is, i removed all VoIP providers.
    And just kept one VoIP provider.
    and now its working.
