No audio on external extension
Discussion in '3CX Phone System - General' started by voipoint, Feb 25, 2011.
  1. voipoint
    Aug 10, 2009
    9
    Hi all,
    I got problem with Yealink IP phones (different models).
    Firmware: 2.60.0.80 (newest from webpage)
    All port on the router are forwarded:
    5060 - SIP (UDP)
    9000-9049 - RTP (UDP)
    I configured phone using manual:
    http://www.3cx.com/blog/voip-howto/remote-extensions/
    PBX address - 188.121.18.xx
    PBX is behind NAT with port forwarding. In the PBX we turn off STUN and set public address.
    Trace from a call:
    Code:
    08:27:33.796  [MS105000] C:2.1: No RTP packets were received:remoteAddr=192.168.5.72:11780,extAddr=0.0.0.0:0,localAddr=188.121.18.xx:9002
    08:27:32.781  [CM503008]: Call(2): Call is terminated
    08:27:17.437  Session 155 of leg C:2.1 is confirmed
    08:27:17.328  Currently active calls - 1: [2]
    08:27:17.125  [CM503007]: Call(2): Device joined: sip:99@127.0.0.1:40600;rinstance=63ce595bc2c81674
    08:27:17.125  [CM503007]: Call(2): Device joined: sip:20@89.228.174.xx:5064
    08:27:17.125  [MS210005] C:2.1:Answer provided. Connection(proxy mode):188.121.18.xx:9002(9003)
    08:27:17.125  [MS210001] C:2.2:Answer received. RTP connection[unsecure]: 127.0.0.1:40612(40613)
    08:27:17.125  Remote SDP is set for legC:2.2
    08:27:17.125  [CM505001]: Ext.99: Device info: Device Identified: [Man: 3CX Ltd.;Mod: Voice Mail Menu;Rev: 1] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Voice Mail Menu] PBX contact: [sip:99@127.0.0.1:5060]
    08:27:17.125  [CM503002]: Call(2): Alerting sip:99@127.0.0.1:40600;rinstance=63ce595bc2c81674
    08:27:16.968  [CM503025]: Call(2): Calling Ext:Ext.99@[Dev:sip:99@127.0.0.1:40600;rinstance=63ce595bc2c81674]
    08:27:16.968  [MS210004] C:2.2:Offer provided. Connection(proxy mode): 127.0.0.1:7002(7003)
    08:27:16.906  [CM503004]: Call(2): Route 1: Ext:Ext.99@[Dev:sip:99@127.0.0.1:40600;rinstance=63ce595bc2c81674]
    08:27:16.906  [CM503010]: Making route(s) to <sip:99@188.121.18.xx>
    08:27:16.906  [MS210000] C:2.1:Offer received. RTP connection: 192.168.5.72:11780(11781)
    08:27:16.906  Remote SDP is set for legC:2.1
    08:27:16.906  [CM505001]: Ext.20: Device info: Device Identified: [Man: Yealink;Mod: T28;Rev: General] Capabilities:[reinvite, no-replaces, unable-no-sdp, no-recvonly] UserAgent: [Yealink SIP-T28P 2.60.0.80] PBX contact: [sip:20@188.121.18.xx:5060]
    08:27:16.906  [CM503001]: Call(2): Incoming call from Ext.20 to <sip:99@188.121.18.xx>
    08:27:16.906  [CM500002]: Info on incoming INVITE:
      INVITE sip:99@188.121.18.xx SIP/2.0
      Via: SIP/2.0/UDP 89.228.174.xx:5064;rport=5064;branch=z9hG4bK1375429119
      Max-Forwards: 70
      Contact: <sip:20@89.228.174.xx:5064>
      To: <sip:99@188.121.18.xx>
      Call-ID: 2037496868@192.168.5.72
      CSeq: 2 INVITE
      Allow: INVITE, INFO, PRACK, ACK, BYE, CANCEL, OPTIONS, NOTIFY, REGISTER, SUBSCRIBE, REFER, PUBLISH, UPDATE, MESSAGE
      Proxy-Authorization: Digest username="20",realm="3CXPhoneSystem",nonce="414d535c0377ead476:5709637020d6b99e648a26b53e45ada0",uri="sip:99@188.121.18.69",response="93dd385417830f15b2de08b9bc8fe299",algorithm=MD5
      Supported: replaces
      User-Agent: Yealink SIP-T28P 2.60.0.80
      Allow-Events: talk, hold, conference, refer, check-sync
      Content-Length: 0
    We tried with 3CX Proxy Manger - its working but customers don't accept this solution.
    Any help or clues are appreciated.
    Thank you,
    Tomasz
    PS: if
  2. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    is it a remote extension or is it an external caller that cannot get the audio?
    It looks like a remote extension and if connecting directly (not through the tunnel) then you will need the "internal" rtp ports open which are in the 7000 udp range.
  3. voipoint
    Aug 10, 2009
    9
    Hi Mark,
    It's a remote extension connected directly to the pbx (the extension is login in to the PBX)
    I just forward ports on router 7000-7500 UDP and still nothing:(
    One more thing...
    I use the instruction from release note SP5
    http://www.3cx.com/blog/releases/3cx-version-9-service-pack-5/
    Note (BETA): 3CX Users that want to register 3CXPhone for Android from an external location can modify a parameter in the custom parameters table of the 3CX Management console (Settings/Advanced/Custom Parameters) “ALLOWSOURCEASOUTBOUND”. Set this to 1 and you will receive 2 way audio upon successful registration. However this might have a negative effect on VoIP Providers so be careful to test this out properly on your environment before.
    I changed “ALLOWSOURCEASOUTBOUND” to 1 and still nothing
  4. abc123
    Nov 9, 2009
    712
    Hi Tomasz
    Can you post the screen shot (less full IPs and usernames) of the basic and advanced screens of a non working yealink.
    The logs you post there show it is trying to send RTP to 192.168.5.xx and I suspect this is the lan on the remote extension not the 3cx lan.
  5. voipoint
    Aug 10, 2009
    9
    Hi Mark,
    You're right the ip address 192.168.5.xx is the ip in LAN of the external extension.
    Basic conf
    Link to image was deleted. Please attach it using "Upload Attachment"
    Advanced conf
  6. abc123
    Nov 9, 2009
    712
    I think it looks ok.
    I have heard of problems with using the latest firmware 2.60.xxx can you downgrade to 2.50.0.50 (I think the new firmware sends the internal ip instead of the stun'd external ip) hence the RTP address is wrong.
    Or you could try (and I am winging it here as I have no idea if this will work, but it is a 2 second change) to put the internal pbx ip in the Sip Server field, Enable the outbound Proxy Server and set the Outbound proxy server to the external IP of your pbx.
    As I say, I have never tried it but we can see if it works.
  7. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    If
    is not blocked then ALLOWSOURCEASOUTBOUND should resolve this issue
    If "border device" blocks traffic to PBX until PBX will send something to the address where from Yealink sends audio then packets from Yealink will not reach PBX and audio will not be available.
    Please don't attach links to the pictures which are resided on third party servers and use Upload Attachment instead.
