No audio on Softphone
Discussion in 'Windows' started by craigreilly, Mar 19, 2012.
  1. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,575
    304
    I have a 3cx server running and can call between iOS devices that are connected internally. So I know we are "working".
    I tested a Mac Softphone and audio travels both ways as well.
    However, I can not get audio in the 3cx Phone for Windows. Even dialing 9999 for voicemail, it rings and connects, but no audio. (Windows 7)
    Firewall if off on Client and Server.
    All of this is internal comm only - nothing thru the corporate firewall (yet).
    11,113
    329
    What does the 3CX log show? Any clue in there?
    Have you tried this on any other PC, it could be an internal PC/audio issue.
  3. craigreilly
    Feb 1, 2012
    3,575
    304
    Same results using my Desktop (win 7) or my Laptop (win 7 on parallels - MB Pro)
    11:14:47.487 [MS105000] C:44.1: No RTP packets were received:remoteAddr=10.0.0.50:40024,extAddr=0.0.0.0:0,localAddr=10.0.0.12:7182
    11:14:46.834 [CM503008]: Call(44): Call is terminated
    11:14:43.030 [CM503007]: Call(44): Device joined: sip:9999@127.0.0.1:40600;rinstance=6a61179f5b034734
    11:14:43.029 [CM503007]: Call(44): Device joined: sip:4954@10.0.0.50:63634;rinstance=7f2cc26daa818452
    11:14:43.025 [CM505001]: Ext.9999: Device info: Device Identified: [Man: 3CX Ltd.;Mod: Voice Mail Menu;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Voice Mail Menu] PBX contact: [sip:9999@127.0.0.1:5060]
    11:14:43.025 [CM503002]: Call(44): Alerting sip:9999@127.0.0.1:40600;rinstance=6a61179f5b034734
    11:14:42.874 [CM503025]: Call(44): Calling Ext:Ext.9999@[Dev:sip:9999@127.0.0.1:40600;rinstance=6a61179f5b034734]
    11:14:42.826 [CM503004]: Call(44): Route 1: Ext:Ext.9999@[Dev:sip:9999@127.0.0.1:40600;rinstance=6a61179f5b034734]
    11:14:42.826 [CM503010]: Making route(s) to <sip:9999@10.0.0.12:5060>
    11:14:42.825 [CM505001]: Ext.4954: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone 6.0.20943.0] PBX contact: [sip:4954@10.0.0.12:5060]
    11:14:42.824 [CM503001]: Call(44): Incoming call from Ext.4954 to <sip:9999@10.0.0.12:5060>
    Using ZOIPER softphone from my Mac I hear audio just fine.
    Even better - the Softphone works fine when outside the firewall - tested on the same MacBookPro with Parallels Win 7 - disconnected from Wifi - plugged hard line into public side of our network and put in the 66.xx.xx.xx external IP. audio works fine.
    So this is pretty strange to me.
  4. craigreilly
    Feb 1, 2012
    3,575
    304
    On my Windows 7 Desktop machine - it was using "High Definition Audio Device" which was installed by default by Windows 7. It works fine for audio in general. 3CX Phone did not like it
    I went to the Dell website and installed the Win 7 specific driver and now audio is working.
    I am assuming similar problem with the Parallels Audio driver on my Mac.
