no audio on toll-free nums
Discussion in '3CX Phone System - General' started by ajohnson443, Apr 10, 2012.
  1. ajohnson443
    Mar 27, 2012
    30
    3Cx v10, all other inbound/outbound local and long distance calls work.
    When dialing a toll-free (800,866,877, etc.) the phone says it's connected, but I never hear a ring, and answer, nothing. Nothing seems abnormal in the server log either. I am guessing my provider is the issue but I want more info before complaining to them. I am a newbie at this whole VoIP PBX/trunk issues :)
    Partial log, first call (bottom is placed to 877 # no audio, next is to 202#, good audio:
    18:53:17.062 [CM503008]: Call(12): Call is terminated
    18:53:16.968 Currently active calls - 1: [12]
    18:53:07.078 [CM503007]: Call(12): Device joined: sip:9046474349@sip.broadvoice.com:5060
    18:53:07.062 [CM503007]: Call(12): Device joined: sip:1001@10.232.1.70:5060
    18:53:06.875 [CM505003]: Provider:[BroadVoice] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:9046474349@108.197.214.151:5060]
    18:53:06.875 [CM503002]: Call(12): Alerting sip:9046474349@sip.broadvoice.com:5060
    18:53:01.875 [CM503025]: Call(12): Calling VoIPline:12027621401@(Ln.10000@BroadVoice)@[Dev:sip:9046474349@sip.broadvoice.com:5060]
    18:53:01.765 [CM503004]: Call(12): Route 1: VoIPline:12027621401@(Ln.10000@BroadVoice)@[Dev:sip:9046474349@sip.broadvoice.com:5060]
    18:53:01.765 [CM503010]: Making route(s) to <sip:912027621401@10.232.1.66>
    18:53:01.765 [CM505001]: Ext.1001: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Cisco-CP7960G/7.5] PBX contact: [sip:1001@10.232.1.66:5060]
    18:53:01.750 [CM503001]: Call(12): Incoming call from Ext.1001 to <sip:912027621401@10.232.1.66>
    18:52:14.906 [CM503008]: Call(11): Call is terminated
    18:52:03.484 [CM503007]: Call(11): Device joined: sip:9046474349@sip.broadvoice.com:5060
    18:52:03.484 [CM503007]: Call(11): Device joined: sip:1001@10.232.1.70:5060
    18:52:02.781 [CM505003]: Provider:[BroadVoice] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:9046474349@108.197.214.151:5060]
    18:52:02.781 [CM503002]: Call(11): Alerting sip:9046474349@sip.broadvoice.com:5060
    18:52:01.000 [CM503025]: Call(11): Calling VoIPline:18776754345@(Ln.10000@BroadVoice)@[Dev:sip:9046474349@sip.broadvoice.com:5060]
    18:52:00.890 [CM503004]: Call(11): Route 1: VoIPline:18776754345@(Ln.10000@BroadVoice)@[Dev:sip:9046474349@sip.broadvoice.com:5060]
    18:52:00.890 [CM503010]: Making route(s) to <sip:918776754345@10.232.1.66>
    18:52:00.875 [CM503001]: Call(11): Incoming call from Ext.1001 to <sip:918776754345@10.232.1.66>
  2. Ian Joyce
    Oct 9, 2009
    51
    This would be an issue with the provider, 3CX for the most part does not differentiate between toll free and regular numbers.
    I would check with them on the issue.
  3. leejor
    10,574
    247
    I have heard of cases where terminating toll free numbers, will not accept calls if they do not like the caller Id that you are sending, such as blocking your number. You provider should be able to assist you with this.
