No audio on trasferred calls and no hold music
Discussion in '3CX Phone System - General' started by purpleone, Jan 29, 2010.
  1. purpleone
    Mar 18, 2009
    18
    Hi all,
    I having trouble with the 3CX server v 8. When calls come in and are put on hold, there is silence - the hold music cannot be heard. I've test this with internal and external calls - both dont work. Also when calls are transferred to another extension, the audio drops. The call stays live, but there is no audio (in or out). Normal internal calls are ok, its only when external calls are transferred to other extensions. The 3CX server has been set as a DMZ on the network, so ports shouldn't be an issue.
    Anyone got any ideas?
    Thanks.
    Luke
  2. glipschitz
    Mar 11, 2009
    I am seeing the same issue on incoming calls.
    I have the line dumping the call to a queue and then ringing the members. The issue is that the call is answered and shows answered in the admin console, yet there is no audio to the end user and the handsets don't ring.
    When the endpoint is a single direct handset, there is no issue.
  3. mylove4life
    mylove4life New Member
    Jan 7, 2010
    165
    Are you using WIn 2008 server?
  4. purpleone
    Mar 18, 2009
    18
    No, I am using Windows XP. This is a small setup with only 2 handsets.
  5. rich1231
    Jan 2, 2010
    I have the same issue and we are on Windows server 2008...is it a known issue?
  6. mfm
    mfm Active Member
    Mar 4, 2010
    641
    Regarding the no audio on transferred calls:
    what phones are you using?
    Can you try and replicate the isue using only soft phones.
    Kindly paste the logs of a replicated call.
  7. Montclairguy
    Feb 23, 2010
    68
