No Audio one way, X-Lite
Discussion in '3CX Phone System - General' started by dcarrion, Aug 24, 2007.
  1. dcarrion
    Aug 24, 2007
    Hello
    Yesterday the 3CX with X-Lite clients was working fine tunelling across a private WAN with a couple of extensions. We had conferencing going, multiple calls, external voip providers etc...
    This morning when we try to use it, there is no audio on one end of the phone. We call an internal extension and the person at the other end hears nothing. We have tried this on multiple computers calling different extensions but same thing. I have also tried reinstalling the server.
    Why would it drop out like that?
    Here is a snipet of some curious logs:
    12:10:12.207|.\CallConf.cpp(120)|Log2|CallControl|CallConf::eek:nIncoming:[CM103002] Call(10): Incoming call from 0102 (Ext.0102) to sip:1301@10.0.1.17
    12:10:12.442|.\CallConf.cpp(178)|Log2|CallControl|CallConf::eek:nProvisional:[CM103003] Call(10): Ext.1301 is ringing
    12:11:03.129|.\Call.cpp(266)|Log2|CallControl|CallLegImpl::eek:nConnected:[CM103001] Call(10): Created audio channel for Ext.0102 (10.0.0.89:63234) with third party (10.0.13.51:10726)
    12:11:03.129|.\CallStrategies.cpp(705)|Log2|CallManager|StratInOut::eek:nConnected:[CM104005] Call(10): Setup completed for call from Ext.0102 to Ext.1301
    12:11:03.145|.\Call.cpp(266)|Log2|CallControl|CallLegImpl::eek:nConnected:[CM103001] Call(10): Created audio channel for Ext.1301 (10.0.13.51:10726) with third party (10.0.0.89:63234)
    12:12:23.129|.\SLServer.cpp(311)|Critical0|MediaServer|MediaServerReporting::RTPReceiver:[MS005001] Call(10) Ext.1301: payload #126 doesn't correspond initial SDP datalen=4
    12:12:27.614|.\CallConf.cpp(120)|Log2|CallControl|CallConf::eek:nIncoming:[CM103002] Call(11): Incoming call from 0102 (Ext.0102) to sip:1301@10.0.1.17
    12:12:27.848|.\CallConf.cpp(178)|Log2|CallControl|CallConf::eek:nProvisional:[CM103003] Call(11): Ext.1301 is ringing
    12:12:33.270|.\SLServer.cpp(311)|Critical0|MediaServer|MediaServerReporting::RTPReceiver:[MS005001] Call(10) Ext.1301: payload #126 doesn't correspond initial SDP datalen=4
    12:12:38.426|.\Call.cpp(266)|Log2|CallControl|CallLegImpl::eek:nConnected:[CM103001] Call(11): Created audio channel for Ext.0102 (10.0.0.89:23282) with third party (10.0.13.51:45226)
    12:12:38.426|.\CallStrategies.cpp(705)|Log2|CallManager|StratInOut::eek:nConnected:[CM104005] Call(11): Setup completed for call from Ext.0102 to Ext.1301
    12:12:38.473|.\Call.cpp(266)|Log2|CallControl|CallLegImpl::eek:nConnected:[CM103001] Call(11): Created audio channel for Ext.1301 (10.0.13.51:45226) with third party (10.0.0.89:23282)
    12:12:38.645|.\SLServer.cpp(305)|Critical0|MediaServer|MediaServerReporting::RTPSender:[MS004001] Call(10) Ext.0102: Can't send RTP stream to 0.0.0.0:63234 destination unreachable
    12:12:38.645|.\SLServer.cpp(305)|Critical0|MediaServer|MediaServerReporting::RTPSender:[MS004001] Call(10) Ext.1301: Can't send RTP stream to 0.0.0.0:10726 destination unreachable
    12:12:43.379|.\SLServer.cpp(305)|Error1|MediaServer|MediaServerReporting::RTPSender:[MS104001] Call(10) Ext.1301: RTP stream to 10.0.13.51:10726 restored.
    12:12:53.848|.\SLServer.cpp(311)|Critical0|MediaServer|MediaServerReporting::RTPReceiver:[MS005001] Call(10) Ext.0102: payload #126 doesn't correspond initial SDP datalen=4
    12:13:03.520|.\CallStrategies.cpp(264)|Log2|CallManager|StratLink::eek:nHangUp:[CM104001] Call(11): Ext.1301 hung up call; cause: BYE; reason: SIP;description="User Hung Up"
    ; from IP:10.0.13.51
    Kind Regards
    Daniel
  2. dcarrion
    Aug 24, 2007
    And then there's logs like this which shows nothing wrong however still no audio at one end.
    14:09:04.784 StratLink::eek:nHangUp [CM104001] Call(2): Ext.0801 hung up call; cause: BYE; reason: SIP;description="User Hung Up"
    14:08:54.940 CallLegImpl::eek:nConnected [CM103001] Call(2): Created audio channel for Ext.0102 (10.0.0.89:9126) with third party (10.0.8.61:11944)
    14:08:54.924 StratInOut::eek:nConnected [CM104005] Call(2): Setup completed for call from Ext.0801 to Ext.0102
    14:08:54.924 CallLegImpl::eek:nConnected [CM103001] Call(2): Created audio channel for Ext.0801 (10.0.8.61:11944) with third party (10.0.0.89:9126)
    14:08:52.924 CallConf::eek:nProvisional [CM103003] Call(2): Ext.0102 is ringing
    14:08:52.627 CallConf::eek:nIncoming [CM103002] Call(2): Incoming call from 0801 (Ext.0801) to sip:0102@10.0.1.17
  3. dcarrion
    Aug 24, 2007
    Okay, this was my problem...Route dropped off private WAN yesterday.
