No audio only on one side
Discussion in '3CX Phone System - General' started by Biber, Dec 8, 2015.
  1. Biber
    Jul 28, 2015
    23
    Since last Monday I have big problems with my 3CX.
    I have a virtual server with only a public ipv4 with only a 3cx installed. The version is v12.5.44178.1002.
    Since Monday I have no audio to some internal phones (Snom 760, 3CXPhone,...) for Example:
    Code:
    From Ext.            To Ext     Phone     Status
       74      <----->    30        Snom     Not Ok
       74      <----->    85        Snom        Ok
       85      <----->    30        Snom        Ok
    The 3CX Firewall-Checker reports no problems. I have tried it with and without a stun-server.
    Sometimes it there is also no audio from external calls.
    Can anybody help me?
    Thanks in advance
    Biber
  2. timvanzee
    Sep 27, 2013
    We've had it on occasion that a phone/extension has a one-way audio problem. Restarting the phone has always resolved it for us. Sorry I can't be more help.
  3. nb
    nb Support Team
    Jun 7, 2007
    2,153
    172
    This is related to firewall mappings being closed or kept open (stale).
    Check firewall rules
    Disable stun
    ensure you have a static public IP
  4. nb
    nb Support Team
    Jun 7, 2007
    2,153
    172
    Disable stun
