No audio - only to one number!? from certain phones?
Discussion in '3CX Phone System - General' started by h2009, Apr 22, 2010.
  1. h2009
    h2009 Member
    Mar 15, 2008
    447
    I'm having a strange issue at the moment. On one of my setups, If i make a call from ext 103 to a number in dubai 0097, the call works without any issues. If I make the same call from any other phone I get no line ringing or audio.
    Now I've got the wireshark logs, but there not telling my this is occurring unless I'm missing something.
    I'd be grateful if someone could look at this just to see if I'm missing any thing.
    P.S Ext 103 is an Aastra phone provisioned by 3CX, per all the other phones (which are a mixture of Snom and Aastra)
    I've tried using and settings different codex on both the PBX and phones, but with no luck.
    The system is not in a NAT - and is fully open to the internet. All other calls to every other number I called work fine from all phones.
  2. comresource
    comresource Member
    May 22, 2009
    303
    Looking at the traces..the working one shows in the SIP INVITE as being from an extension "103@192.168.0.200" but the non working one shows the from being "441273818365@sip.orbistelecom.com"
    Is the non working phone on the same 3CX system?
  3. h2009
    h2009 Member
    Mar 15, 2008
    447
    Sorry I forgot to mention that when I looked a the ncap. The one which isn't working seems to be going direct to the sip provider, rather than the PBX.
    Yes they are both on the same system, both extension are 100% idenitical in every way other than the ext number.
    This is what I can't seem to get my head around. If everything is the same then why is this occurring?
    I've tried doing a master reset on the phone, auto provision/manual provision/semi-provision but none of it is working. I could understand if no numbers are working, but if all but this number is working its very strange.
  4. mfm
    mfm Active Member
    Mar 4, 2010
    641
    For such an issue, it would be best if we could diagnose it by means of a ticket. Kindly open a ticket a we will assist you from there.
  5. h2009
    h2009 Member
    Mar 15, 2008
    447
    HI thanks for your reply - I thought it would be best here since Aastra's are not supported?
  6. comresource
    comresource Member
    May 22, 2009
    303
    If possible could you post a sanitized copy of the phone provisioning file?
  7. h2009
    h2009 Member
    Mar 15, 2008
    447
    Sure I can do - but its just the standard configuration which comes with 3CX at installed- I haven't actually editted at all.
    So did you still want it?
  8. comresource
    comresource Member
    May 22, 2009
    303
    It wouldnt hurt to see it. Also if you could pull the server.cfg and local.cfg from the phone web interface just to compare.
  9. leejor
    11,282
    360
    Could it have anything to do with the "deliver audio via PBX" option on the line?
  10. h2009
    h2009 Member
    Mar 15, 2008
    447
    Thanks for everyone's replys here is the all the documents requested.
    Also I thought that it could be PBX to deliver audio - but then why would every other call work other this particular number? Surely it wouldn't work at all if it needed to be on?
    - 3 files all text documents
  11. comresource
    comresource Member
    May 22, 2009
    303
    Nothing jumps out as being wrong. There is quite a bit of info in the local.cfg for the working phone. My local.cfg files are only about 5 lines. When you get a chance do a complete Factory Reset on both phones and reboot them. This will assign only what is in the provisioning file. Verify this by looking the the local.cfg after it should only have the MD5 entries. Test dialing on both phones. If the results are the same..one working..and one not then something in 3CX extension specific must be off.
  12. h2009
    h2009 Member
    Mar 15, 2008
    447
    Oh right that is strange. I actually only yesterday did another factory reset via the webpage. I'll give it ago directly on the phone.
    Thanks again
