No Audio Over Internet for calls
Discussion in '3CX Phone System - General' started by jmatson, Dec 24, 2009.
  1. jmatson
    jmatson New Member
    Nov 30, 2009
    122
    I have a problem and i must be fixed.
    If i setup a softphone or any other deivce outside my network. I get no audio. Unless i tunnel in. but not all decives support that.
    Server is on a Public IP. with Nat disabled. No firewalls.
    11,117
    329
    A common problem but many possible solutions. Does the "remote" extension have STUN enabled? Have you tried calls from only one outside hotspot, or a number, with the same problem? Is it no audio at all or one way audio?
  3. jmatson
    jmatson New Member
    Nov 30, 2009
    122
    i have disabled stun and enabled stun. with no luck. it's no audio both ways. I have tried using my iphone using 3g. used my laptop at my buddies shop. many places with no luck
  4. leejor
    11,117
    329
    I would recommend always using STUN on the remote end if the phone is behind a router that you have no control over to set port forwarding. If 3Cx is on a public IP and there is no firewall software running (something that could be blocking ports) then I'm not sure what would be blocking the audio ports but allowing ports 5060 and 5090 to get through. Does the firewall check on 3Cx pass? What does the 3Cx log look like when the far end initially registers (non tunnel), sometimes that can give a clue as to what is wrong.
  5. jmatson
    jmatson New Member
    Nov 30, 2009
    122
    yes firewall passes. i'll post logs sat when i head to my buddies again.
  6. jmatson
    jmatson New Member
    Nov 30, 2009
    122
    ok im in town made a call from my iphone yo my wife over sip she could hear me but i couldnt hear her
    here are the logs
    14:43:47.304 [CM504002]: Ext.100: a contact is unregistered. Contact(s): [sip:100@10.1.10.33:5060/100,sip:100@10.1.10.13:55424;rinstance=895cdf1ae80fcc1d/100]
    14:43:37.775 [CM503008]: Call(68): Call is terminated
    14:43:17.532 Session 15836 of leg C:68.1 is confirmed
    14:43:16.982 [CM503007]: Call(68): Device joined: sip:10000@10.1.10.16:5062
    14:43:16.978 [CM503007]: Call(68): Device joined: sip:100@166.137.136.252:16651
    14:43:16.976 [MS210003] C:68.1:Answer provided. Connection(transcoding mode[unsecure]):74.93.147.249:9002(9003)
    14:43:16.972 [MS210001] C:68.2:Answer received. RTP connection[unsecure]: 10.1.10.16:16384(16385)
    14:43:16.970 Remote SDP is set for legC:68.2
    14:43:16.970 [CM505002]: Gateway:[ATT] Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA3102-3.3.6(GW)] PBX contact: [sip:10000@74.93.147.249:5060]
    14:43:16.970 [CM503002]: Call(68): Alerting sip:10000@10.1.10.16:5062
    14:43:16.898 [CM503025]: Call(68): Calling PSTNline:4692992@(Ln.10000@ATT)@[Dev:sip:10000@10.1.10.16:5062]
    14:43:16.896 [MS210002] C:68.2:Offer provided. Connection(transcoding mode): 74.93.147.249:7354(7355)
    14:43:16.877 [CM503004]: Call(68): Route 1: PSTNline:4692992@(Ln.10000@ATT)@[Dev:sip:10000@10.1.10.16:5062]
    14:43:16.860 [CM503010]: Making route(s) to <sip:4692992@sip.esteswireless.com>
    14:43:16.858 [MS210000] C:68.1:Offer received. RTP connection: 166.137.136.252:16659(16660)
    14:43:16.855 Remote SDP is set for legC:68.1
    14:43:16.855 [CM505001]: Ext.100: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Siphon PjSip v1.4-trunk/arm-apple-darwin9] PBX contact: [sip:100@74.93.147.249:5060]
    14:43:16.852 [CM503001]: Call(68): Incoming call from Ext.100 to <sip:4692992@sip.esteswireless.com>
    14:43:16.736 [CM500002]: Info on incoming INVITE:
    INVITE sip:4692992@sip.esteswireless.com SIP/2.0
    Via: SIP/2.0/UDP 166.137.136.252:16651;rport=16732;branch=z9hG4bKPj2TtZeMR-zIVcOCsetMIkvHvrIjidaAxv
  7. leejor
    11,117
    329
    OK, now I'm confused, where does the 3102 come into this?? I thought that you were calling back to an internal 3CX extension from a remote 3Cx extension? Nothing involving a PSTN line. So you are dialing back out to a landline? Do you get audio both ways from the external extension calling another extension on the same LAN as 3CX? If so then it's not a router/firewall port issue, it's something in the 3102 settings.
    I'm seeing "transcoding" in the logs so it sounds like all of the SIP devices (the 3102)are not using the same codec. I'd go with G711u as first choice.
  8. jmatson
    jmatson New Member
    Nov 30, 2009
    122
    it's the same result both ways. if i call a ext say voice mail. i don't hear audio. if i call a ext number no audio.
    Inside my LAN everything works great.
  9. leejor
    11,117
    329
    What are you behind at the "remote" end? Have you tried running the remote extension on the open net with a public IP. That would eliminate the router/firewall at the remote end as the problem. Obviously audio packets aren't able to get through to you.
    Have you tried making calls from another location, different router?
  10. jmatson
    jmatson New Member
    Nov 30, 2009
    122
    remote end. is on my Iphone.
    I have tried using a 3cx softphone on my buddies network and it doesn't work
    right not. my server has a Public Static IP with no firewall at all. not even on my router
  11. leejor
    11,117
    329
    What software are you using on the iPhone, that might be the cause of the trouble. i don't use one so I'm not familiar with any of the settings available. Used 3 different makes of Wifi phone, a couple of PC with the 3CX soft-phone and a number of ATA's and 95% of the time there is no problem. the only time I get issues is when certain public hotspots have some sort of port restrictions to prevent/restrict VoIP use and then I can usually get through using the tunnel. You may want to check out the forums dedicated to the app you are using on the iPhone.
    Are you using the iPhone through WiFi or using your providers data service? I have heard of some mobile provider attempting to block the use of VoIP on their networks.
  12. eagletech
    Mar 17, 2009
    I also have this issue with Iphone and the acrobits softphone. Cannot get audio to work from this iphone sip app. Does work on several other providers. But cannot get it to work with 3cx, using same parameters as used in pther providers and 3cx does work with pc softphone sip apps.
    Are you using the Acrobits softphone for iPhone?
  13. jmatson
    jmatson New Member
    Nov 30, 2009
    122
    i am using Siphon
  14. King Computer
    Jul 5, 2009
    8
    acrobits iphone 3cx settings
    The usual cause of no audio will be that the RTP ports are not set correctly on the client SIP phone or the correct ports are not being forwarded to the 3CX server.
    If you are using an iPhone with acrobits sip phone see the article below on configuring it to access externally through wifi so the audio traffic works.
    http://technicians-blog.kingcomputer.com.au/index.php/configure-acrobits-sip-iphone-app-to-externally-access-3cx-voip-server-so-rtp-voice-traffic-works
  15. King Computer
    Jul 5, 2009
    8
    See this article fro configuring acrobits on the iphone
    http://technicians-blog.kingcomputer.com.au/index.php/configure-acrobits-sip-iphone-app-to-externally-access-3cx-voip-server-so-rtp-voice-traffic-works/
  16. instantexpert
    Dec 2, 2008
    92
    I have this same problem using iSip and Weephone for iPhone. If I am inside my network, I can make and receive calls. If I am outside my network, I get one way audio. I have a public IP with all appropriate ports open and the problem occurs over 3G, Wifi, and regardless of whether I use STUN or not.
    Leon
  17. instantexpert
    Dec 2, 2008
    92
    I was able to make this work from my home wifi network by adding stun.3cx.com into the stun field and, otherwise, following the instructions for Acrobits. However, calls over 3G still result in one-way audio.
    Leon
  18. StaffKB
    Jan 5, 2010
    97
    Hi there,
    Does this work if you use WIFI in a different location to your PBX?
  19. instantexpert
    Dec 2, 2008
    92
    Yes, there are slightly different settings for inside and outside my network but I can make calls just fine from my home network.
    I should mention that it does not (yet) work over 3G even though all three of the SIP phones I have on my iPhone now support calls over 3G.
    Leon
  20. itc7
    Feb 16, 2010
    hi, we are experiencing the same problem, works fantastically over wifi, but 3g no audio can be heard on the Iphone handset, and the call quality the person the other hears is very broken and poor. Does anyone have any suggestions on this?
    Barry
