No Audio, SVR08 Virtual on Hyper-V, Remote Aastra 6751i
Discussion in '3CX Phone System - General' started by xotj123, Nov 14, 2010.
  1. xotj123
    May 21, 2010
    I am running 3cx on a Virtual machine hosted at a datacenter. Running Wind SVR 2008 R2...., I am attempting to use a Aastra 6751i as a remote extenstion. It registers and can make calls, but there is no audio....
    19:01:46.688 [MS105000] C:10.2: No RTP packets were received:remoteAddr=70.164.0.244:10040,extAddr=0.0.0.0:0,localAddr=70.182.141.254:7020
    Any Ideas?
    Regards,
    TJ Havens
    11,293
    361
    No audio, in both directions? Lack of audio is almost always caused by blocked or misdirected packets, router or firewall issues. Have you set up the remote phone to use STUN.
  3. xotj123
    May 21, 2010
    Yes, it is set to use stun. Any other ideas?
    Regards,
    TJ Havens
