No Audio through a PPTP VPN
Discussion in 'iOS' started by mhnichols, Nov 29, 2010.
  1. mhnichols
    May 22, 2009
    11
    HI,
    I have been trialling the iphone client, All works well in the office on WIFI, but when using the PPTP VPN on the iphone to connect to our office, The client registers Ok, but when making a call there is no audio, either sent or received?
    Regards
    Mark
  2. mfm
    mfm Active Member
    Mar 4, 2010
    641
    I actually had great success with this, but it sounds like you might be misconfiguring it..
    1. Make sure all you settings are internal..
    2. Make sure stun is switched off and any other helpers.
  3. mhnichols
    May 22, 2009
    11
    HI, Yes it was a setup issue,
    The following corrected the problem.
    In 3CX for Iphone Account Settings, Remove, External Server address and Stun Address.
    In Iphone VPN PPTP Setup, Ensure "Send All Traffic" is on!.
    This means that you must remove the settings input by the auto provisioning, (probably best not to use auto provisioning in this type of setup!)
    Thanks for the advice
    Mark
