No audio when dialing 1300 xxx xxx & 13 xx xx numbers
Discussion in '3CX Phone System - General' started by moore, Oct 18, 2010.
  1. moore
    Feb 24, 2010
    10
    I have recently installed 3CX v9 on a virtual win 7 box, and i can not hear the audio when i call 1300 and 13 numbers.
    We have 2 accounts one with ISPhone and the other for Internode both in Australia.
    We have has a older version of 3CX installed with the same providers and it worked, is there something i have to do to activate 1300 ect calls, mobile/ call phone calls work fine.
    This is what my service activity log reads>>>>
    14:42:08.311 [CM503007]: Call(27): Device joined: sip:101@10.10.2.201:5060
    14:42:07.138 [CM505001]: Ext.101: Device info: Device Identified: [Man: Cisco;Mod: SPA Series;Rev: General] Capabilities:[reinvite, replaces, unable-no-sdp, no-recvonly] UserAgent: [Cisco/SPA525G-7.4.6] PBX contact: [sip:101@10.10.2.6:5060]
    14:42:07.138 [CM503002]: Call(27): Alerting sip:101@10.10.2.201:5060
    14:42:07.059 [CM503025]: Call(27): Calling Ext:Ext.101@[Dev:sip:101@10.10.2.201:5060]
    14:42:06.996 [CM503004]: Call(27): Route 1: Ext:Ext.101@[Dev:sip:101@10.10.2.201:5060]
    14:42:06.994 [CM503010]: Making route(s) to <sip:101@10.10.2.6:5060>
    14:42:06.990 [CM505003]: Provider:[Internode] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:0290434790@121.223.223.130:5060]
    14:42:04.112 [CM503003]: Call(28): Call to sip:101@10.10.2.6 has failed; Cause: 487 Request Terminated; from IP:10.10.2.201:5060
    14:42:04.004 [CM503008]: Call(28): Call is terminated
    14:42:02.278 Currently active calls - 2: [27,28]
    Thankyou.
    Darren
    10,585
    252
    I see a call to ext 101 but no call attempt to a 1300... number. If some numbers, through the same providers, work, and other are having issues, then...be sure you are , in fact, sending the correct digits. If you are, then it sounds like an issue with your provider, or, something that they may be able to shed some light on, by looking at the call logs, from their end. You can try re posting an outgoing call attempt by one of your extensions to both a working number and a non-working 1300 number.
  3. will
    Mar 18, 2010
    I have a ticket open on a similar issue. In the mean time I wanted to engage the user community.
    My installation was a v8 (tested extensively) then upgraded to v9 (also tested extensively) problem started after last night's v9 SP3 upgrade.
    No Audio on 800 or 888 outbound calls after upgrade to v9 SP3 - can't complete a toll free call.
    Voip or PSTN - does not matter.
    Other outbound calls are working without issue - no issue with inbound.
    I also noticed the IVR Services pegging some high cpu (and then calming) - the install is on a Server 2003 R2 SP2 w/ IIS.
    Any ideas?
    -Will
  4. moore
    Feb 24, 2010
    10
    Hey all again, ok i have tried tweeking some things in Cisco but still same ol, this is now the complete call log i just made to Telstra 132203 number. i chose telstra because you will always have a long Hold time LOL.
    10:52:53.439 [MS105000] C:12.2: No RTP packets were received:remoteAddr=203.2.134.1:18008,extAddr=121.223.223.130:9014,localAddr=121.223.223.130:9014
    10:52:52.462 [CM503008]: Call(12): Call is terminated
    10:52:36.454 Currently active calls - 1: [12]
    10:52:36.119 Session 1642 of leg C:12.1 is confirmed
    10:52:36.054 [CM503007]: Call(12): Device joined: sip:0290434790@sip.internode.on.net:5060
    10:52:36.036 [CM503007]: Call(12): Device joined: sip:102@10.10.2.202:5060
    10:52:36.014 [MS210001] C:12.2:Answer received. RTP connection[unsecure]: 203.2.134.1:18008(18009)
    10:52:36.011 Remote SDP is set for legC:12.2
    10:52:35.949 [MS210003] C:12.1:Answer provided. Connection(transcoding mode[unsecure]):10.10.2.6:7034(7035)
    10:52:35.946 [MS210001] C:12.2:Answer received. RTP connection[unsecure]: 203.2.134.1:18008(18009)
    10:52:35.944 Remote SDP is set for legC:12.2
    10:52:35.941 [CM505003]: Provider:[Internode] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:0290434790@121.223.223.130:5060]
    10:52:35.940 [CM503002]: Call(12): Alerting sip:0290434790@sip.internode.on.net:5060
    10:52:31.801 [CM503025]: Call(12): Calling VoIPline:132203@(Ln.10000@Internode)@[Dev:sip:0290434790@sip.internode.on.net:5060]
    10:52:31.764 [MS210002] C:12.2:Offer provided. Connection(transcoding mode): 121.223.223.130:9014(9015)
    10:52:31.380 [CM503004]: Call(12): Route 1: VoIPline:132203@(Ln.10000@Internode)@[Dev:sip:0290434790@sip.internode.on.net:5060]
    10:52:31.374 [CM503010]: Making route(s) to <sip:1132203@10.10.2.6>
    10:52:31.374 [MS210000] C:12.1:Offer received. RTP connection: 10.10.2.202:16438(16439)
    10:52:31.371 Remote SDP is set for legC:12.1
    10:52:31.370 [CM505001]: Ext.102: Device info: Device Identified: [Man: Cisco;Mod: SPA Series;Rev: General] Capabilities:[reinvite, replaces, unable-no-sdp, no-recvonly] UserAgent: [Cisco/SPA525G-7.4.6] PBX contact: [sip:102@10.10.2.6:5060]
    10:52:31.342 [CM503001]: Call(12): Incoming call from Ext.102 to <sip:1132203@10.10.2.6>
    10:52:31.295 [CM500002]: Info on incoming INVITE:
    INVITE sip:1132203@10.10.2.6:5060 SIP/2.0
    Via: SIP/2.0/UDP 10.10.2.202:5060;branch=z9hG4bK-1c0afb0a
    Max-Forwards: 70
    Contact: "Darren Geyer"<sip:102@10.10.2.202:5060>
    To: <sip:1132203@10.10.2.6>
    From: "Darren Geyer"<sip:102@10.10.2.6>;tag=92fe3733857af89eo0
    Call-ID: 108f6697-2d0af08a@10.10.2.202
    CSeq: 102 INVITE
    Expires: 240
    Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER, UPDATE
    Proxy-Authorization: Digest username="102",realm="3CXPhoneSystem",nonce="414d535c02d011bf44:19832e0b21fcd972728ce936e9d32376",uri="sip:1132203@10.10.2.6:5060",algorithm=MD5,response="71328d7c25ba87ef5b248d8247b03244"
    Supported: replaces
    User-Agent: Cisco/SPA525G-7.4.6
    Content-Length: 0
  5. moore
    Feb 24, 2010
    10
    Hey all
    I have now just added ISPhone to our 3CX box and tested it with 132203 (a known working Telstra number) now i get a lady stating that "the number is incomplete or incorrect" with the following numbers O2TD11 Thirty.
    so maybe 3CX is adding or deleting numbers when we dial 13 xx xx 1300 xxx xxx numbers
  6. leejor
    10,585
    252
    This what you are dialling (1132203)
    This is what the outbound rules are routing the call on (1132203)
    This is what 3CX is going to send out after passing through your outbound rules (132203)
    This is the actual call being placed sending out 132203, is this number the correct one that you want to send out? More importantly, is this the number your provider wants to see? If not, then you need to correct your outbound rules.
  7. moore
    Feb 24, 2010
    10
    Yes this is a Telstra Number (just a test).
    Ok this is the set up... Internode is on prefix 1, ISPhone is on prefix 2...
    so to dial out number "132202" using internode you will have to type "1" to select internode and then the phone number "132202" in total it will be "1132202" then in the out bound rule we strip the first digit so the number becomes "132202" yeah! so this is correct, we have tested the number on our cell phones it all works well.
    Now news to hand... 13/1300 number sometimes work with internode and now any number sometimes fail. when this happens next i will attach the call log.
  8. leejor
    10,585
    252
    Well...this is what i would suggest. If call problems are intermittent (I hate that type of problem), before pointing fingers at your provider, and it may very well be their problem, use Wireshark and collect a record of some failed calls. Record the times/dates as your provider may have logs that they can check as well. You will then have documentation showing that you sent the correct digits, but the calls still failed. You also have something you can email to them when you confront them. Just be certain that the Wireshark logs back you up.
  9. Discovery Technology
    Apr 19, 2008
    278
    My money is on it being the provider, however you may want to workshop your wireshark results with them to see if you need to adjust your outbound SIP field matching in your trunks.
    I have done this before with Internode and after a while achieved some success, however you'll need to be patient as you work through this with them.
    We are using Nexvoice (in Australia also) and dialling the 132203 number works no problems otherwise - I suspect most other VoIP providers would probably work just as well.
