No audio
Discussion in 'Windows' started by netcam, Mar 26, 2008.
  1. netcam
    Mar 26, 2008
    I have just installed the 3cx system and got it all setup with the softphone. I configured it and connected to the server ok and can call other extensions and leave voice mails (I know this because I get the email with the voice mail and it also is noting the mail duration) although I hear no prompt to leave a message, I also try to call extension 999 and get no prompt at all just silance. I can hear the ring and dial tone fine...
    Am I doing something wrong? I have also checked in the properties to make sure the audio device were set correctly and they are both the same "Ringing Device & Playback Device"
    Thanks for any help! I am really looking forward to working with this system.
    I hope this is not a stupid question.
    Thanks,
    Jonathan
  2. netcam
    Mar 26, 2008
    Please disregard this post... I fixed the issue, it was a windows firewall thing!
    Sorry to ask such a silly question.
    Thanks,
    Jonathan
