no call from IP Phone Thomson 2030
Discussion in '3CX Phone System - General' started by effeelle, Sep 29, 2010.
  1. effeelle
    Sep 29, 2010
    I have 2 IP Phones Thomson 2030. I configured the user on the phone.
    the phone is registered properly on the PBX and receives all calls without problems.
    but I can not make any calls, not domestic ones.
    when I compose a number I get the message "Wrong Number"
    HELP ME!! :cry:
    this is a major problem for me,
    I rated this PBX to buy, but I have to solve this problem because I have 5 phones equal
    thank's
    Effe
  2. jsadan
    May 3, 2010
    91
    How is your outbound rule currently setup?
  3. effeelle
    Sep 29, 2010
    yes the rule for outbound is ok and with the softphone I call without the problem.
    with the Thomson I can even call the internal numbers
    thank's
    effe
  4. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,557
    118
    You mean can't. Right? :p
    I'm moving this in the General Section as it is prone to get more attention there rather than here as this is the 3CX VoIP Phone forum.
  5. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,970
    273
    These phones are not supported for use with 3CX, so if you insist on using these phones its best to look for another PBX solution.
  6. effeelle
    Sep 29, 2010
    RESOLVED Re: no call from IP Phone Thomson 2030
    why should I change the PBX?
    I banged my head but I solved the problem!
    must reset the phone to factory state, updated firmware, configured the user and everything is solved!
    effe
