No Call logs Reporter
Discussion in '3CX Phone System - General' started by lotsu99, Dec 29, 2008.
  1. lotsu99
    Jan 1, 2008
    27
    Hi~~
    Is the Call Logs Reporter working in the V7 ???
    it doesn't work in my system ??
  2. discovery1
    discovery1 Member
    Aug 4, 2008
    355
    It works for me - what sort of problem are you having?
  3. Nebula
    Nebula New Member
    Apr 6, 2008
    116
    Works for me too.
    Probably a dumb comment but you do realise you need MS Access installed to read the .mdb file created by Call Reporter?
