No caller ID for outside transfers?
Discussion in '3CX Phone System - General' started by scythe000, Mar 13, 2012.
  1. scythe000
    Nov 8, 2011
    66
    So, when the receptionists transfer a call to an outside line, the recipient only sees the internal extension, ie, '1001', not the phone number of the call they are transferring. Is there any ability to correct this?
    10,732
    277
    How is she receiving these calls? Are they direct (from an outside trunk) to her, or transferred from another set? If from another set, is it a blind or attended transfer?
  3. scythe000
    Nov 8, 2011
    66
    Blind transfer from outside line.
  4. leejor
    10,732
    277
    This seems to suggest checking to see if the reception line is set to support re-invites.
    http://www.3cx.com/forums/transferred-calls-using-transferers-id-rather-than-orginator-10540.html#p63934
    But also suggests using blind transfer, which you say you already are.
    It might also have something to do with the make/model, or settings on the receptionists set, you didn't say what it was.
  5. scythe000
    Nov 8, 2011
    66
    They are using Polycom 550IPs.
    How can I check to see if re-invites are supported?
  6. leejor
    10,732
    277
    In the 3CX extension options, I recall that being one of several options that you can select (tick boxes). As far as the set...I'm not familiar with that make/model. Hopefully someone else can supply additional information. The manual might be worth a look.
  7. scythe000
    Nov 8, 2011
    66
    Found it. Support re-invites is checked.
  8. leejor
    10,732
    277
    It may be a set issue. Here is someone having the same issue, same make set, different PBX.
    http://www.pbxinaflash.com/community/index.php?threads/yealink-t-26-transferring-callerid-with-call.11475/
    I'm not sure I agree with the DTMF link to the problem.
  9. scythe000
    Nov 8, 2011
    66
    Hmm...I wonder if we could get a 3CX dev to confirm...
  10. albertc
    Nov 21, 2011
    89
    Did you check the "Outbound caller ID" under the "Other" tap within the user Extension?
  11. scythe000
    Nov 8, 2011
    66
    It's blank. Since we're talking about incoming external calls, I don't think it would apply, right?
