No Caller ID from SPA 3102
Discussion in '3CX Phone System - General' started by mcbsys, Aug 15, 2010.
  1. mcbsys
    mcbsys New Member
    Oct 8, 2008
    179
    15
    Just installed 3CX 9.13545 Free and applied Service Pack 1.
    Accepting inbound PSTN through a Linksys 3102 with software version 5.1.10(GW).
    I used the provisioning to reset the 3102 configuration. There are some inconsistencies with the manual configuration guidelines. One is the "PSTN CID For VoIP CID" setting, which I set to Yes.
    However I'm not getting CID from the 3102. It was working with Asterisk/PBX in a Flash. It seems like the 3CX is not waiting until the second ring so it can collect the CID, but I don't see where to set that.
    BTW I'm in San Diego, California.
    What am I missing?
    Thanks,
    Mark Berry
    MCB Systems
    10,752
    285
    The field that tells the 3102 how long to wait before sending the caller ID to 3CX is under the PSTN tab/FXO Timer Values/PSTN Ring Through delay. The default is 5 (seconds) so if you did a factory reset it should work. I have found that 3 seconds is the minimum you can get away with, anything less will miss the CID info, at least in North America.
  3. mcbsys
    mcbsys New Member
    Oct 8, 2008
    179
    15
    Thanks leejor. It eventually dawned on me that this is a 3102 setting, not a 3CX setting.
    I did not do a factory reset. Instead I used the provisioning file created by 3CX, which seems to set every value. It sets PSTN Ring Through Delay to 1.
    Interesting that it is working for you by adjusting PSTN Ring Through Delay. That's supposedly "Delay in seconds before starting to ring thru Line 1 after the PSTN starts ringing." I don't want the 3102 to ring its own Line 1 directly, so I set PSTN-To-VoIP Gateway Setup > PSTN Ring Thru Line 1 to No. 3CX default is to disable Line 1 altogether but I am using that as an extension so I need it to to act independently from the PSTN side.
    Anyway I found that by setting FXO Timer Values > PSTN Answer Delay up from 0 to 3, I am able to see Caller ID.
  4. leejor
    10,752
    285
    Sorry, my mistake, that was the option that I meant to point you towards. It ends up being the cause of most caller ID problems, at least here in North America. the ring through to line 1 is an option that should be disabled if you want to use the FXS port as a 3CX extension.
  5. mcbsys
    mcbsys New Member
    Oct 8, 2008
    179
    15
    No worries, it's working now! Thanks for taking the time to reply...
