No caller ID since upgraded from 10 to 11
Discussion in '3CX Phone System - General' started by dlazure, Aug 26, 2013.
  1. dlazure
    Nov 5, 2012
    65
    Hi guys
    I recently upgraded a system from version 10 to 11 and i lost caller id.
    we actually get the PSTN gateway port identification number as the caller id on incomming calls.
    the gateway is a vegastream 50 europa. caller id is set to ON in the config
    10,362
    227
    If the 3CX logs do not show the outside caller ID, then the gateway is not passing it on to 3CX. Was there a firmware/settings update done to the gateway that may have changed an option? Is CID set to the correct method for your region/country?
    Have you confirmed, with the use of a stand-alone caller ID device, that you are getting CID on the lines?
  3. dlazure
    Nov 5, 2012
    65
    Thanks for the reply
    I did not went on site yet. Where should i check the CID setting for the right country ?
    When i did the upgrade i had to reload the setting in the gateway. maybe something went wrong
    thanks
    EDIT : 26-Aug-2013 15:22:12.081 L:342.2[Ivr] has joined to L:342.1[Line:10006<<+151410006]
    514 is the area code
  4. leejor
    10,362
    227
    So, the caller ID is being passed onto 3CX? Is it just that the trunk number is also being passed and not a name?
  5. dlazure
    Nov 5, 2012
    65
    514 is the area code + 10006 is the gateway port number. no caller id is passing
  6. dlazure
    Nov 5, 2012
    65
    my customer said on the display he see the name of the caller + the port number ( 10006 )
    but not the number
    i went to inbound parameter in the gateway and everything is like default
    im lost
  7. leejor
    10,362
    227
    If the same number (154410006) is being passed for every call, no matter what the originators area code, then this number is in the gateway, somewhere. On many gateways, if they receive no caller Id they will send a field that had been datafilled, to identify where (what gateway) the call came in on. Is the gateway waiting long enough for the Caller Id to be received. In North America it comes between the first and second ring. Many times, a gateway has been set-up to pass the call onto the PBX before getting the CID information.
    Where you able to confirm that caller Id is coming in on the PSTN lines? It's up to the gateway to pass this on. 3Cx is simply displaying what it receives from the gateway.
    So, it is either a setting in the gateway, that is incorrect, or the gateway is not receiving caller Id from the provider.
    If the gateway has been re-provisioned by 3CX since you upgraded, then that might be it. Is the firmware of the gateway at the correct release for the provisioning file created by 3CX. Is 3CX creating a provisioning file for the correct device, correct country?
  8. dlazure
    Nov 5, 2012
    65
    would i be able to modify the number of rings before the gateway pickup in the gateway webpage ? or i need to do it when i create the gateway.
    but if the name is being collected, i am pretty sure the number should be there too.
  9. dlazure
    Nov 5, 2012
    65
    from the log in the pstn gateway i can see this
    27/08/2013 21:04:04 21:04:14 0/00:00:09 16 0202 9901
    from: TEL:514908XXXX,NAME:LUMINET to: dest: TEL:10006,TA:192.168.60.50:5060,TELC:10006
    so it confirm the CID on the lines.
  10. leejor
    10,362
    227
    If you are seeing the name and number in the gateway, then it obviously "gets them". I'm not familiar with that gateway to know off hand if there is an option that is substituting the trunk number for part of the phone number. You would not think that would be something that people would want, but there may be an option to format incoming caller ID, like adding a "9" to the number, so that some PBX users can redial the number from the caller ID.
    If the 3CX log isn't showing the full number, as received, then the gateway isn't sending it, and the options in the gateway require checking.
  11. tarmeeb
    Aug 28, 2013
    19
    I'm no expert at all, a complete n00b , but what I have gathered from online tutorials is:
    Look for the CID settings of your VOIP or PSTN provider, what protocol they are using...and modify your gateway accordingly..
    If you find this answer very trivial or unrelated to your issue, be gentle :D
  12. dlazure
    Nov 5, 2012
    65
    i know what caller id type we receive from canadians provider. canada standard.
    gr30-mdfm
  13. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,962
    180
    do you perhaps have the ability to install a new v11 system with just 1 extension and test with this gateway? It is possible something is afoul in the Gateway settings within 3cx that occurred in the upgrade from v10 to v11.
  14. bardissi
    bardissi Member
    Jan 31, 2012
    318
    Why dont you do yourself a favor and reprovision the gateway using the templates in V11 and see where you stand after that
