No Caller-Id to mobile
Discussion in '3CX Phone System - General' started by blue26, Oct 25, 2012.
  1. blue26
    Sep 11, 2012
    I can't get the caller-id to mobile phones working.I always get blocked as CID
    To other internal or external VOIP phones no problem.
    Does anyone know how to fix this
    Thanks in advance
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,086
    64
    What kind of service is used to get the originating call?
  3. blue26
    Sep 11, 2012
    I call from my VOIP Extension to a cellphone, the cellphone gets a blocked CID.
    when i call to another VOIP phone (extern) he gets my CID or any CID i provide for my extension
  4. lneblett
    Sep 7, 2010
    2,086
    64
    Let's try again.......
    How do your outbound calls get connected...PSTN using gateway, PRI, sip, etc.?
    How does the caller-I'd get presented to a landline phone (not an extension)?
  5. leejor
    11,105
    329
    If your outbound calls, route over the same trunks, and calls to a landline show your caller-ID, then, in theory, it should show on a call to a mobile as well.
    But, as Ineblett, said, you need to provide more information.
