- Joined
- Jul 14, 2009
- Messages
- 1
- Reaction score
- 0
Working awesome for months; suddenly none of the extensions register. No changes were made to the configuration. Trying 3cx softphone the result is:
Attempting to connect [--deleted by me--]
Using network interface 127.0.0.1
Phone got as local port 54214
RTP engine OK
SIP engine OK
Sound mic device OK
Sound ring device OK
Sound play device OK
Phone is sending STUN request
Phone connection failed, server not responding
Looking at server logs, no registration attempts are shown for my extensions (100, 101, 102, 103). Firewall test passes. Same problem if I shut off the firewall on the server. All extensions were working fine until last week. One extension became unregistered and wouldn't register. Then a day later the others became unregistered. Has this happened to anyone else? Is my ISP suddenly blocking some ports as of last week? I can't figure out what has changed on the network.
This is the startup log (there is no activity at all if I try to register an extension):
12:37:11.520 [CM504001]: Ext.801: new contact is registered. Contact(s): [sip:[email protected]:40600;rinstance=c467baafac595617/801]
12:37:11.512 [CM504001]: Ext.800: new contact is registered. Contact(s): [sip:[email protected]:40600;rinstance=e9c9d756d283ac27/800]
12:37:11.425 [CM504001]: Ext.999: new contact is registered. Contact(s): [sip:[email protected]:40600;rinstance=29e1a74105cc2672/999]
12:37:09.318 [CM504001]: Ext.*1: new contact is registered. Contact(s): [sip:*[email protected]:40000;rinstance=96af6b55c1f7c2d0/*1]
12:37:09.258 [CM504001]: Ext.*0: new contact is registered. Contact(s): [sip:*[email protected]:40000;rinstance=2ce9de569ec43fa0/*0]
12:37:08.674 [CM504002]: Ext.*1: a contact is unregistered. Contact(s): []
12:37:08.629 [CM504002]: Ext.*0: a contact is unregistered. Contact(s): []
12:37:04.786 [CM504001]: Ext.704: new contact is registered. Contact(s): [sip:[email protected]:40300;rinstance=b87facb8cfc86381/704]
12:37:04.776 [CM504001]: Ext.703: new contact is registered. Contact(s): [sip:[email protected]:40300;rinstance=8695fe3a795536c3/703]
12:37:04.764 [CM504001]: Ext.702: new contact is registered. Contact(s): [sip:[email protected]:40300;rinstance=743c631ae71b0ae7/702]
12:37:04.748 [CM504001]: Ext.701: new contact is registered. Contact(s): [sip:[email protected]:40300;rinstance=dc04b0634dc3801b/701]
12:37:04.741 [CM504001]: Ext.700: new contact is registered. Contact(s): [sip:[email protected]:40300;rinstance=78809b63ce01bfe5/700]
12:36:58.528 [CM504008]: Fax Service: registered as sip:888@--deleted by me--:5060 with contact sip:888@--deleted by me--:5100;user=phone
12:36:55.445 *** Connected to XENU:5482/CallManager at 127.0.0.1:5482 ***
12:36:55.440 [CM112000] Media Server is connected
12:36:54.378 [CM504002]: Ext.801: a contact is unregistered. Contact(s): []
12:36:54.376 [CM504002]: Ext.800: a contact is unregistered. Contact(s): []
12:36:54.374 [CM504002]: Ext.999: a contact is unregistered. Contact(s): []
12:36:53.859 [CM504002]: Ext.801: a contact is unregistered. Contact(s): []
12:36:53.852 [CM504002]: Ext.800: a contact is unregistered. Contact(s): []
12:36:53.838 [CM504002]: Ext.999: a contact is unregistered. Contact(s): []
12:36:52.557 [CM504010]: Fax Service: unregistered contact sip:888:5100;user=phone
12:36:52.049 [CM504010]: Fax Service: unregistered contact sip:888:5100;user=phone
12:36:49.784 [CM504002]: Ext.704: a contact is unregistered. Contact(s): []
12:36:49.781 [CM504002]: Ext.703: a contact is unregistered. Contact(s): []
12:36:49.777 [CM504002]: Ext.702: a contact is unregistered. Contact(s): []
12:36:49.774 [CM504002]: Ext.701: a contact is unregistered. Contact(s): []
12:36:49.720 [CM504002]: Ext.700: a contact is unregistered. Contact(s): []
12:36:49.259 [CM504002]: Ext.704: a contact is unregistered. Contact(s): []
12:36:49.253 [CM504002]: Ext.703: a contact is unregistered. Contact(s): []
12:36:49.242 [CM504002]: Ext.702: a contact is unregistered. Contact(s): []
12:36:49.233 [CM504002]: Ext.701: a contact is unregistered. Contact(s): []
12:36:49.216 [CM504002]: Ext.700: a contact is unregistered. Contact(s): []
12:36:46.578 *** Server shut down ***
12:36:46.578 *** Server started ***
12:33:56.348 [CM504008]: Fax Service: registered as sip:888@--deleted by me--6:5060 with contact sip:888@--deleted by me--:5100;user=phone
12:28:56.184 [CM504008]: Fax Service: registered as sip:888@--deleted by me--:5060 with contact sip:888@--deleted by me--:5100;user=phone
12:23:56.018 [CM504008]: Fax Service: registered as sip:888@--deleted by me--:5060 with contact sip:888@--deleted by me--:5100;user=phone
12:19:33.908 [CM504001]: Ext.801: new contact is registered. Contact(s): [sip:[email protected]:40600;rinstance=eb91c54196eb8142/801]
12:19:33.899 [CM504001]: Ext.800: new contact is registered. Contact(s): [sip:[email protected]:40600;rinstance=cfcc3d3e7b0efa98/800]
12:19:33.894 [CM504001]: Ext.999: new contact is registered. Contact(s): [sip:[email protected]:40600;rinstance=42f257f3cea39e6d/999]
12:19:22.698 [CM504001]: Ext.*1: new contact is registered. Contact(s): [sip:*[email protected]:40000;rinstance=e713b9f7d37892d2/*1]
12:19:22.687 [CM504001]: Ext.*0: new contact is registered. Contact(s): [sip:*[email protected]:40000;rinstance=bdcfaeecc51a61f0/*0]
12:19:22.257 [CM504001]: Ext.704: new contact is registered. Contact(s): [sip:[email protected]:40300;rinstance=a5e225ee88ab9c42/704]
12:19:22.244 [CM504001]: Ext.703: new contact is registered. Contact(s): [sip:[email protected]:40300;rinstance=95e3c8cbd8911a87/703]
12:19:22.237 [CM504001]: Ext.702: new contact is registered. Contact(s): [sip:[email protected]:40300;rinstance=23557007f0f58fb5/702]
12:19:22.150 [CM504001]: Ext.701: new contact is registered. Contact(s): [sip:[email protected]:40300;rinstance=4618370229ffc20f/701]
12:19:22.116 [CM504001]: Ext.700: new contact is registered. Contact(s): [sip:[email protected]:40300;rinstance=1513632401ad8c86/700]
12:19:16.119 *** Connected to XENU:5482/CallManager at 127.0.0.1:5482 ***
12:19:16.116 [CM112000] Media Server is connected
12:19:01.268 [CM504004]: Registration succeeded for: 10001@Inphonex
12:19:01.210 [CM504004]: Registration succeeded for: 10000@Unlimitel
12:19:01.104 [CM504003]: Sent registration request for 10001@Inphonex
12:19:01.103 [CM504003]: Sent registration request for 10000@Unlimitel
12:19:01.012 IP(s) added:[--deleted by me--]
12:18:55.872 [CM504008]: Fax Service: registered as sip:888@--deleted by me--:5060 with contact sip:888@--deleted by me--:5100;user=phone
12:18:55.473 [CM504004]: Registration succeeded for: 10001@Inphonex
12:18:55.291 [CM504004]: Registration succeeded for: 10000@Unlimitel
12:18:54.999 [CM504003]: Sent registration request for 10001@Inphonex
12:18:54.997 [CM504003]: Sent registration request for 10000@Unlimitel
12:18:53.341 [CM506002]: Resolved SIP external IPort (--deleted by me--:5060) on Transport --deleted by me--:5060
12:18:53.264 [CM506001]: STUN request to resolve SIP external IPort mapping is sent to STUN server 75.101.138.128:3478 over Transport --deleted by me--:5060
12:18:51.015 [CM501007]: *** Started Calls Controller thread ***
12:18:51.014 [CM501006]: Default Local IP address: [--deleted by me--]
12:18:50.948 [CM501002]: Version: 7.1.7060.0
12:18:50.947 [CM501001]: Start 3CX PhoneSystem Call Manager
12:18:50.664 Unknown system [DBProvider] tries to connect!
12:18:50.567 [CM501009]: License Info: Loaded Succeeded
RTP engine OK
SIP engine OK
Sound mic device OK
