philduvlu
- Joined
- Sep 4, 2013
- Messages
- 4
- Reaction score
- 0
I spend lot of time to find the response to my problems on the internet, without success.
I rent a VPS with Windows 2012 Std where I installed 3cx phone system.
The Windows's Firewall is done in these test session because my VPS is protected by a hardware firewall where I opened ports 5060 and 5090 TCP and UDP (INPUT), I let also the 5060 opened in OUTPUT but I can deleted it, only 9000 ports can be configured in Output. I opened ports from 9000 to 9007 (I'm limited to 20 others free ports to configure on the firewall), so I will be limited to 4 simultaneous calls, enough for us, and too much for the test version.
Firewall test is OK, green for all lines.
Here is the two logs that come when I try to connect my 3CX phone client on my Iphone, thanks to help me to configure 3CX (maybe the server of firewall) in order to be able to test 3CX:
10.0.0.41 is the local IP address of the server and 185.7.214.48 the Public IP.
----- first log:
SIP request (SUBSCRIBE) from 178.254.99.137 was rejected. Reason: Block WAN requests is ON.
Message:
SUBSCRIBE sip:[email protected]:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.36:5060;rport=61086;branch=z9hG4bKPjn6abJwZtqrzgLXh8SPxefvuVq9wWXqWt;received=178.254.99.137
Max-Forwards: 70
Route: <sip:10.0.0.41:5060;lr>
Contact: "Philippe Duvivier"<sip:[email protected]:5060;ob>
To: "Philippe Duvivier"<sip:[email protected]:5060>
From: "Philippe Duvivier"<sip:[email protected]:5060>;tag=LpBwLfg3J43uNtO4yt9ohRagASEyHHuS
Call-ID: AmDSoXYTbTuQkL5aq8NL7xV0BZ1CCz3x
CSeq: 31399 SUBSCRIBE
Expires: 3600
Accept: application/simple-message-summary
Proxy-Authorization: Digest username="21",realm="3CXPhoneSystem",nonce="414d535c08390f4258:8141d6cffcf8ec75c3798a07094d2997",uri="sip:[email protected]:5060",response="542529dd7fe7100da004c237bcc0c95d",algorithm=MD5
Supported: replaces, 100rel, timer, norefersub
User-Agent: 3CXPhone for iPhone 3.0.41
Event: message-summary
Allow-Events: presence, message-summary, refer
Content-Length: 0
-------- second log:
SIP request (REGISTER) from 178.254.99.137 was rejected. Reason: Block WAN requests is ON.
Message:
REGISTER sip:10.0.0.41:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.36:5060;rport=61086;branch=z9hG4bKPjL0YgsQPjfYjBH5f8g4Cxj7NVOiUr.lib;received=178.254.99.137
Max-Forwards: 70
From: "Philippe Duvivier"<sip:[email protected]:5060>;tag=FZunnqh8w6aAGEhX-js5Y0adXZU5yF8d
Call-ID: btPEkbr2D7MWfqNHO8cfsWRSqoFKrqw9
CSeq: 12908 REGISTER
Expires: 3600
Allow: PRACK, INVITE, ACK, BYE, CANCEL, UPDATE, SUBSCRIBE, NOTIFY, REFER, MESSAGE, OPTIONS
Proxy-Authorization: Digest username="21",realm="3CXPhoneSystem",nonce="414d535c08390f4213:bb3c4678c47ab4c91903210b3113a85d",uri="sip:185.7.214.48:5060",response="ca59cf229aafc473a35911ef8a196fe0",algorithm=MD5
Content-Length: 0
Thanks for your help.
Kind Regards
Ph. Duvivier
----- first log:
Message:
Max-Forwards: 70
Expires: 3600
Content-Length: 0
Message:
Max-Forwards: 70
Expires: 3600
Content-Length: 0
Kind Regards
Ph. Duvivier
