no connection via isdn - pstn - check that authorization-ID
Discussion in '3CX Phone System - General' started by LugmayrM, Dec 19, 2007.
  1. LugmayrM
    Dec 7, 2007
    7
    If i call my isdn number there is no connection.
    Gateway:
    Patton
    Model SN4552/2BIS/EUI
    Serial Number 00A0BA03409C
    Hardware Version 2.1
    Software Version R4.2 2007-09-19 SIP
    The error message in 3cx:
    Authentication failed for SipReq: INVITE anonymous@192.168.0.170:5060 tid=33b588e39 cseq=INVITE contact=6602813001@192.168.0.248:5060 / 411305390 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    I do not know why there is autentification.
    In 3cx gateway i configured
    Require (optionally: authorized) registration for: Nothing (doesn't require registration at all)
    The gateway is registered.
    thx for help
    martin
