No create ring group after upgrade version 3.1 2295
Discussion in '3CX Phone System - General' started by clavaud, Jun 27, 2007.
  1. clavaud
    Jun 27, 2007
    25
    No possible valid extension in the ring group in version 3.1 2295
  2. Costas3CX
    Costas3CX New Member
    Jan 23, 2007
    217
    Hello sir and welcome to the forums of 3CX phone system
    what do you mean exactly "No possible valid extension in the ring group in version 3.1 2295"
    Can you explain so I can help you?What are you trying to do, and what doesn't work?
  3. clavaud
    Jun 27, 2007
    25
    not possible create ring group with version 2295
  4. Costas3CX
    Jan 23, 2007
    217
    Sir, can you please go to START/RUN/services.msc
    restart 6 services of 3cx phone system
    After you restart please try and create the ring group. After it fails go to your 3cx management console and go to General/Support and generate support info.
    Please send me this info at my email and I will look at it.
    From what version did you upgrade to 2295?
  5. clavaud
    Jun 27, 2007
    25
    respons at costas 3cx Create ring group
    Up grade at version 3.0.1928.0 to v3.1 2295
  6. Costas3CX
    Jan 23, 2007
    217
    what machine are you running this on? vista or xp?
  7. clavaud
    Jun 27, 2007
    25
    I turn on Windows 2000 pro
  8. Costas3CX
    Jan 23, 2007
    217
    Hello sir, I think the issue was with the old database of version 1928. Please try and backup the existing configuration you have on version 2295, and restore it again on the same 2295 version. This should clear up the database and hopefully fix any problems.
    Let me know if this fixes the problem.
  9. Anonymous
    Anonymous Guest
    Should we get some common understanding on what version is what?
    Is there a
    Or should it be v3.0.2328.0 ?
    Now I am confused.
  10. clavaud
    Jun 27, 2007
    25
    Backup and restore data base on version 2295. The problem persite
