No Dial Tone - Dialing out
Discussion in 'Windows' started by dpcatkins1983, Dec 6, 2016.
  1. dpcatkins1983
    Dec 6, 2016
    We have a slight issue where sometimes when dialing out, the user doesn't get a Dial Tone, have tried another headset the only way to fix this is to reboot her PC, but this is not always the best case, anyone got any ideas
    Client is using
    intel NUC
    Intel Celeron 2.15GHz
    4GB RAM
    Windows 10 Pro
    Headset is a BT42
    Anyone got any ideas what it could be? have unplugged the USB headset and back in still not working
  2. ALuisPV
    Mar 7, 2016
    28
    Hi ,
    I would check that the Operating System is completely updated and if there are new versions of drivers related to USB. Check the motherboard manufacturer website and look there if there are any updates.
    Does this headset work fine in other machine ?. The result of this test can be helpful in order to determine where you can have the issue.
    Best Regards.
