No dial tone when a line is open
Discussion in 'Windows' started by rjm2884, Mar 13, 2018.
  1. rjm2884
    Feb 21, 2018
    19
    On the Windows client, we don't get a dial tone when we open the line. On the Mac client, dial tone works each time.
    Any ideas?
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,569
    302
    Is this really needed? The Open Line feature doesn't really do anything in VoIP. The call does not start when you begin dialing or take the phone off hook. It starts when you hit SEND. All instructions are then sent to the Server for processing.
    This fake dial tone does nothing on the Mac.
    Vali_3CX likes this.
  3. rjm2884
    Feb 21, 2018
    19
    Craig thanks for the clarification. We just needed to confirm if this was a bug or an error on our end.
  4. craigreilly
    Feb 1, 2012
    3,569
    302
    It is possible it is a bug - but as long as the device is making outbound calls and receiving them, I would call it a-ok! :)
  5. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,527
    71
    @rjm2884
    Craig is right - the dialtone (together with touchtones, busy tone and even ringtone) is just a simple audio feedback to the user. Part of the call are the ringback and in-band DTMFs.
    craigreilly likes this.
  6. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,557
    118
    We'll consider adding this to all our clients at some point.
    Markus Schröder and craigreilly like this.
