NO DIGITS DISPLAYED after dialling prefix 9
Discussion in '3CX Phone System - General' started by yaca, Oct 10, 2008.
  1. yaca
    Oct 9, 2008
    15
    Is it normal that the digits of the dialled number don't display on the phone once the Number Prefix has been pressed? The prexif 9 routes to the PSTN line so there is a PSTN line tone after 9 but it's a bit frustrating the users don't see the numbers punched on the phone after 9.
    Many thanks for any suggestions to this.
  2. galal202
    galal202 New Member
    Jun 23, 2008
    235
    This 2 stage dialing
    dial all your number in 1 step
    what is your ip phone and pstn gateway?
  3. yaca
    Oct 9, 2008
    15
    Thanks for a quick reply. I am using SPA3102 as a gateway and telephones SPA942, SPA901 and ATAs PAP2T. I also have a n Outbound Rule for VoIP SIP Trunk that does not require Number Prefix so I just dial straight away the number and that looks good but to go out through PSTN I guess I have to dial Number Prefix.
    Thanks for all your help.
  4. Cjay
    Cjay New Member
    Feb 24, 2007
    203
    5
    No - this is not normal. Following on from your other thread this would seem to confirm a dial plan issue in your 942 that is forcing immediate dial out after certain digits are entered and effectively giving you 2 stage dialling. What is your SPA942 dial plan (the one in the phone, not in 3cx)?
    Chris
  5. yaca
    Oct 9, 2008
    15
    Hi Chris,
    Thanks for chasing this up. Indeed I have a dial plan that immidiatelly dials up after 9. I did that because when I wanted to dial the whole number with 9 in front of it I suddenly got a an outside PSTN dial tone somewhere in the middle of inserting the digits. The dial tone looks like that:
    (P9 | 9S0 | [1-8]xxS0 | *xx | [3469]11 | 0 | 00 | [2-9] xxxxxx | 1xxx [2-9] xxxxxxS0 | xxxxxxxxxxxx.)
    What would be your suggestion to change this dial plan to enable 1 stage dialing with 9 in front to go out to PSTN as well as dialling 14 or more digits numbers wihtout number prefix?
    Thanks in advance.
    Remy
  6. galal202
    galal202 New Member
    Jun 23, 2008
    235
    this the original dial plan
    (*xx|[3469]11|0|00|[2-9]xxxxxx|1xxx[2-9]xxxxxxS0|xxxxxxxxxxxx.)
    and it works fine
  7. yaca
    Oct 9, 2008
    15
    Thanks, I will give it a try. I think I actually started off from the default dial plan on the phone...
  8. mickp
    Jun 9, 2008
    72
    If you have numbers that start with 9 that you could possibly need to dial then i'd suggest setting a length for the dial plan in 3cx or choose another number.
    Mick.
