no Email Notifications
Discussion in '3CX Phone System - General' started by NickK, Jul 9, 2013.
  1. NickK
    Feb 27, 2010
    45
    Hi, i moved my 3cx comp running win server 2010r2 to Rogers ISP on Hitron modem/router and everything is working except email notifications. What could i check to troubleshoot this?
  2. jasit
    jasit New Member
    Feb 12, 2013
    171
    Are you hosting the mail server or is someone else? If you changed ISP's they may not allow you to router smpt messages without authenticating to the SMTP server first.
  3. tom_ch
    Jul 6, 2011
    69
    for diagnostics, just try it over Telnet and see how far you get.
  4. leejor
    10,767
    286
    Have you used a valid "senders" email address in 3CX. Some ISPs will not allow emails to be sent if it appears you are spoofing the senders address.
    If you have a look at the 3Cx logs, (probably using verbatim setting) , is there any error regarding the email?
  5. NickK
    Feb 27, 2010
    45
    im using smtp.1and.com from my hosting provider, i just switched to gmail, will try if it works.
    original sender is proper email address, should be no problem with it. I dont know how to use telnet really.
  6. NickK
    Feb 27, 2010
    45
    which logs do i check? server logs?
  7. tom_ch
    Jul 6, 2011
    69
    It's quite useful for mail-related issues because you can see the answers of the mail server.
    See here: http://www.wikihow.com/Send-Email-Using-Telnet
  8. NickK
    Feb 27, 2010
    45
    emails from my computer is ok. what other things i could check? or which log has showing failed attempts? server logs?
  9. NickK
    Feb 27, 2010
    45
    also server log has no word "email" in its log..
  10. tom_ch
    Jul 6, 2011
    69
    go to your 3CX server, try to send an e-mail over Telnet with the credentials you entered in 3CX Console.
    What happens?
