No email sent on voice mail
Discussion in '3CX Phone System - General' started by MatsW, Oct 2, 2013.
  1. MatsW
    Mar 10, 2009
    50
    I have configured voicemail with email option "Send as attachment and delete from mbox", but I'm not getting any emails. Is 3CX server logging failures somewhere ?
  2. MatsW
    Mar 10, 2009
    50
    If I take a network trace on the 3CX server then there is no attempt to send anything to the mailserver when I record a voice mail. It therefore seems like the email is either never generated or blocked by the 3CX server.
  3. leejor
    10,594
    255
    Are you using a licence, or the "Free" version?
    Did any emails, of any type, like error messages, ever work? If not then your email server settings may require some tweaking.
  4. MatsW
    Mar 10, 2009
    50
    This is a licensed installation. It used to work, but it hasn't been working for quite some time. But now I really need to get this working. What is odd is that I can't see any signs of the 3CX server even trying to contact the mail server.
    Is there some way to get some more debugging info from 3CX server to see what it does ?
  5. MatsW
    Mar 10, 2009
    50
  6. kevin
    kevin Member
    Nov 23, 2006
    316
    you might find some pointers in CallHistoryService.log
  7. MatsW
    Mar 10, 2009
    50
    CallHistoryService.log didn't have anything of interest (it seemsed), but 3CXIvrServer.trace.log showed the following
    19:29:42.589|3524|api\VXItelImpl.cpp(148):IvrDll, VXItelImpl::Impl::IntrnTransfer(), Error! Error of 'From_15_To_11_Menu_RecordMessage_#0/10' session transferring to sip:11@127.0.0.1:5060. Status: NEAR_END_DISCONNECT. Transfer error. Session stopped
    If this can give some clue
  8. kevin
    kevin Member
    Nov 23, 2006
    316
    You can safely ignore this message, it is unrelated to the email sending process...
  9. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    Send the welcome email to an address you can access.. the system will at least complain when it doesn't work there.
    If it does not, do what you can at the SMTP server.. like the log files. I know, not always possible if you don't also manage that.
  10. MatsW
    Mar 10, 2009
    50
    The reason why my mailserver (Exchange 2010) didn't receive/accept any voicemail or other event messages from the 3CX server was that Exchange 2010 comes with a default server hub-transport configuration which requires sender that is on the same subnet as the Exchange server to provide authenticaion for a valid Windows user (See Exchange Management Console / Server configuration / Hub transport / Receive connectors / Default < server name>).
    What is odd thou is that I'm not getting any event-mails even if I've enabled the event "Log in and out of 3CX management console" and set the same receive email address as used for testing voicemail.
  11. ian.watts
    Apr 8, 2011
    532
    Take it for what it's worth, I tend to configure an open relay receive connector and add the PBX address (and other sending hosts) to it.
    When you try to send the welcome email for an extension.. it will at least "tell" you when it failed.. versus wondering or checking for mail.. or MTA logs..
