No external ring tone on Sipgate
Discussion in '3CX Phone System - General' started by Scientio, Feb 12, 2008.
  1. Scientio
    Mar 24, 2007
    8
    I have vonage and sipgate accounts, plus a single SPA300 POTS line. 3CX version is 5.0.3790.0 running on Windows 2003
    Callers on the sipgate line hear no ringtone. My phones ring internally however, and the caller ID is correctly received.
    Log shows nothing wrong:
    18:37:55.358 Call::Terminate :[CM503008]: Call(3): Call is terminated
    18:37:55.343 LineCfg::getInboundTarget :[CM503011]: Inbound out-of-office hours' rule for LN:10002 forwards to DN:19
    18:37:47.202 CallCtrl::eek:nSelectRouteReq :[CM503004]: Call(3): Calling: Ext:19@[Dev:sip:19@192.168.1.10;user=phone]
    18:37:47.202 Line::printEndpointInfo :[CM505003]: Provider:[sipgate] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] Transport: [sip:192.168.1.4:5060]
    18:37:47.202 LineCfg::getInboundTarget :[CM503011]: Inbound out-of-office hours' rule for LN:10002 forwards to DN:19
    18:37:47.187 CallCtrl::eek:nIncomingCall :[CM503001]: Call(3): Incoming call from ************@(Ln.10002@sipgate) to [sip:19@phonesystem.********.com:5060]
    How can I get a ring tone for external callers?
    Thanks,
    Andy
  2. bluefox8080
    bluefox8080 New Member
    Oct 28, 2007
    181
    I you pick-up the call at the office, can the other party (from Sipgate) hear you?
  3. Scientio
    Mar 24, 2007
    8
    Yes, everything is fine apart from the lack of ring tone.
  4. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Andy,
    It is not related to Sipgate,
    Subject should be:
    3CX PBX doesn't show ringing state of my SPA NNNN
    Answer will be: "please upgrade your version to 5.1 beta or 5.1 RC"
    You will see ringing state of your SPA device on Line Status page and SIPGATE will "rings", because SPA alternative is supported in version specified above.
    Regards
  5. Scientio
    Mar 24, 2007
    8
    Hi Stephan,
    That doesn't make any sense. My copy of 3cx connects directly to Sipgate, not via the SPA 300 - I've got an analog line on that.
    I'm happy to upgrade, but how can the SPA affect the direct digital connection to Sipgate?
    Best wishes,
    Andy
  6. Scientio
    Mar 24, 2007
    8
    I've upgraded to 5.1. the problem is still there.
    Andy
