No funct "answer key" on Jabra headset with 3CX softphone.
Discussion in '3CX Phone System - General' started by Datorfixarna2, Dec 12, 2009.
  1. Datorfixarna2
    Dec 12, 2009
    I have a Jabra bluetooth headset but I can not answer with the built in answer button with 3CX softphone connected. Any solution?
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,531
    69
    At this moment, 3CXPhone only supports Plantronics headsets - but we have plans to integrate Jabra in the near future.
    vali
  3. DeWild1
    Oct 31, 2008
    86
    Drugs are bad man.. :mrgreen:
    This, http://www.plantronics.com/north_america/en_US/support/softwaredownloads/personocall_consumer.jsphttp://www.plantronics.com/north_america/en_US/support/softwaredownloads/personocall_consumer.jsp
    Plus this, http://www.amazon.com/Plantronics-Bluetooth-USB-Adapter-BUA-100/dp/B000MT7BBA
    plus any damn BT headset you like works just fine. hang up and answer with button on headset.
    I personally recommend the JAWBONE dot COM for the best quality sound plus you can work in a noisy environment and have calls like you are in a private office.
    :lol: 8)
  4. DeWild1
    Oct 31, 2008
    86
    Also, Plantronics has a new version of their "PerSonoCall" software, http://www.plantronics.com/north_america/en_US/support/softwaredownloads/personosuite.jsp , but on my Win XP, I have NEVER got it to work and I do not remember if it worked on Vista..
    that's why I use the old software.. If it aint broke, don't fix it!
  5. Datorfixarna2
    Dec 12, 2009
    Re: No funct "answer key" on Jabra headset with 3CX softphon
    It's really bad that 3CX not supporters of the excellent "Jabra GO 6430" hedset on the website:
    It has a long range of approximately 100 meters and is therefore far better placed than any "Plantronics". Surely it can not be a problem to fix this?
  6. Datorfixarna2
    Dec 12, 2009
    From http://www.3cx.com/ordering/sample-configs.html: "Headsets: Bluetooth headsets which can be used in combination with the softphone are available from Plantronics, Jabra and others. On average they cost $50 each.". How can they recommend Jabra WITHOUT the possibility to answer with headset answer button?
